Question about Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear - Whirlpool Calypso GVW9959K Top Load Washer
  • 254 Answers
This is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Posted on Feb 02, 2010
I just had the FL code and couldn't get the washer to stop beeping or reset itself. So I unplugged the washer and followed the advise of the women who said she drained her washer with the drain hose on the back of the washer. I put pressure on the hose to get the water to start coming out. Had to do that several times but it worked! The washer is now working fine.
Posted on Mar 06, 2010
  • 28 Answers
SOURCE: Kenmore Elite Calypso Washer agitator malfunction
you either have too much stuff in it or something that gets under
the agitator or it has a weak transmission
Posted on Mar 16, 2008
SOURCE: Sears Kenmore Calypso Washer
yes. It did, then it goes to the 'FL' mode. I don't know what 'FL' means. When I first bought the machine, I did ask for a manual. The little Sears store I bought it from in Kingman, Arizona had given the manual out on loan to another customer who never returned it. This is the first problem I've had with the machine, so did not give it another thought.
Thank you,
Posted on May 14, 2008
SOURCE: Washer displays FL code
I GOT THIS OFF THE MANUAL, HOPE THIS HELPS.
"FL' (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Posted on Jun 08, 2009
  • 49 Answers
SOURCE: my kenmore elite calypso keeps beeping Fl what
FL (flood condition) also can be an indicator of a bad pump. The washer tries to drain and cannot because the pump has failed or is jammed with debris.
You can run a complete washer diagnostic procedure to see if you can isolate the fault by doing the following. I recommend you make sure the room is quiet so you can hear the pump motor running when expected, as well as the main drive that nutates and spins.
Perform a "key dance" to put the washer in the diagnostic mode by pressing the Prewash Options button, Wash Time, Prewash Options, Wash Time - each 2 times in rapid succession within 5 seconds total. The display will change to 99 and begin counting down (in seconds) as it runs the following tests. Listen for the pump motor to actually run and not just "hum", indicating a jam or burnout.
Display 99-81, Nutate & fill
Display 80-61, Nutate & recirculate
Display 60-41, Nutate, Fill & drain **
Display 40-21, Nutate, Fill & drain **
Display 20-0, Spin & drain **
You can cancel the test in progress at any time by pressing the Stop/Cancel button.
**during these phases the pump will run forwards and backwards (recirculate & drain). If you do not hear water pumping inside the washer or draining out the drain, your pump is likely bad and needs to be replaced.
The old style pump was a two-part assembly and the re-engineered part # mentioned above is a single piece that solves the impeller failure problem the original pumps were prone to have.
www.pcappliancerepair.com sells replacement pump part # 285990 for this washer and they are a reliable supplier with a good value. You can purchase a lifetime warranty on the pump from them for an extra fee.
Unfortunately there is not enough room in this text box to post the pump removal & replacement procedure but you can get your local handyman to do the work for you if you are not inclined, as I was, to drain the washer and turn it on its side to figure out how to replace the pump.
The other problem is that once you start getting a pump failure you need to look at the root cause. If the pump was ruined by draw strings or debris being sucked into the pump impeller, it is time to replace the top wash plate assembly (the plastic plate inside the washer that the clothes sit on).
There is a rubber seal on the outside edge of this plate which wears out over time and rotates upward, opening a bigger gap between the plate and the stainless steel drum which lets draw strings and other things get sucked all the way down into the pump. The upper wash plate & seal is a single unit and the seal itself cannot be replaced as it is molded into the plastic piece. Order this from Sears to insure a more recent 'cure date' on the rubber seal from the manufacturer, rather than 3rd party suppliers who might stock the part for longer periods and have old rubber seals past their cure date. The wash plate should be replaced about every other year.
Posted on Oct 03, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Calypso error code reads FL...
Press STOP/CANCEL to clear the display. http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Should you continue to have appliance issues or need parts or service advice, please don’t hesitate to contact us. We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella :>)
Posted on Nov 08, 2009
Keeps getting fl error message
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
Jan 27, 2016 | Washing Machines
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Just replaced the motor and pump, 3 weeks ago. Now I am getting an ld and then an FL?? Calypso Kenmore washer Elite
The FL error code means:
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore calypso wont rinse and displays the fl code.
Flood Condition:
Feb 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do you reset the overfill switch on the kenmore Elite calypso machine? It shows FL and we cut the power. There is water inside
Flood Condition:
Nov 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Calypso SM9710976A has "FL" on front panel. Whats wrong?
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^!!$#
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
Calypso washmachine
you have a flood condition,,or overfill,,we must get rid of the water it seems the pump cant do it,,also it can be tripped or make this display fl if to much suds are in unit ..press stop than cancel and it will clear...than put unit in drain,,if water doesnt drain we have a drain problem that caused the fl error..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
FL code on a Kenmore Calypso top loader
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
413 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
