Question about Freezers
Whirlpool fridge working but not staying cold
I have a whirlpool frigde, 454Lt it is 10 years old. The fridge is working (ie power and fan are working) but it is not staying cold.
    President:
  • 1,515 Answers
Hi, I am assuming you are talking about the fan in the freezer that is working? If you will take these steps for me, pull the unit out enough for you to get behind it and have room, there will be a panel at the bottom that you can remove. You will have another fan, the condenser fan and coil there. Make sure the temperature control is set for the unit to run and make sure this motor is running. If not, the motor is faulty. If it is running, make sure the compressor is on and running. It will be HOT so be careful, but put you're hand on it and you will know if it is on. If it is not on and it is very hot, more then likely the compressor has failed. You may want to clean the front of the coil while you are back there as if it is very dirty, this can cause high head pressures in the system causing the compressor to shut off. Go through these steps and keep me posted on what you have found and what these componants are doing.
Sincerely,
Shastalaker7
Posted on Feb 02, 2010
  • 454 Answers
Check the freezer for ice build-up. You will need to remove the rear and bottom covers for this. Frequently, ice will build up in the passageway between the refrigerator and freezer and/or in the defrost drain. If you remove this ice, your refrigerator will resume normal operation.
My chest freezer (10 years old) won't freeze. Motor is running and the red indicator light remains on, but neither the amber or green lights are working.
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Regards.
May 01, 2011 | Whirlpool 10 cu. ft. Chest Freezer...
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, wgheaven@yahoo.com.au Russ
Mar 28, 2011 | Whirlpool Freezers
The frigde is turned dow but still freezing all
your cold temperature control is bad, not shutting the unit down when the temperature is correct. needs to be replaced.
Mar 23, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Hi, my kelvinnator frigde seems to not be as cold as usual, I turned down the fridge thermostat hoping that it would fix the problem, but not yet. I also noticed water droplets forming on the inside top...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 01, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Gladiator fridge/freezer-freezer not cold enough, stays at 10 deg
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 12, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridge Freezer is blowing out hot air, is this fixable and cheap to fix?
is this under warranty? not a year old? thermostat or low refrigierent in compressor.thermo replace price ok.comp refrig can be expensive. hope this helps
May 21, 2009 | Whirlpool Freezers
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
GE Fridege TBX18J MS not getting cold
hi is the fan motor going in the freezer. if so how long has it been plugged in if more than 24 hrs and the fan is going. it could be that because it sat for 10 years the lines that go inside could have rusted out. so if this is the case its scrap sorry. the appliance doc.
Oct 16, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Fridge not cooling
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Sep 30, 2007 | Freezers
Freezers Logo
80 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
