Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a 4000 watt coleman powermate that is fifteen years old and approx 200 hrs on it. Had it running during a blizzard and the motor pulled down and now only puts out half power.Could swirling snow have ruined it?
  • dkilian Feb 02, 2010
    pulled down similar to overload on engine then came back to full rpm s
  • GetMeOttaHere May 11, 2010
    What is meant by motor pulled down? Motor is not running at a fast enough rpm??
  • 122 Answers
Yes, swirling snow could have done some damage. Any snow that may have gotten inside had enough heat to melt it but not evaporate it. It would be overly difficult to try and explain how to take it apart over the internet. I would suggest taking it to a small engine repair shop. Is it running at full rpm with half the power or running at half the rpm at half power?
Posted on Feb 02, 2010
  • 2,926 Answers
I'm thinking you go it wet and it should be ok once it dries.
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
My Powermate 200 went into fault on last power up.... and buzzes, what now?
Make sure it getting the power it needs to run. Plug into another car while the car is running.
May 08, 2011 | Coleman Powermate 200 Watt Compact DC/AC...
I'm looking for an owners manual for a Coleman Powermate 4000
You may not be able to find the owners manual, but if you search using model / type #s off the engine, you may be able to find the manual for the engine from the manufacturer.
May 07, 2010 | Coleman Electrical Supplies
Coleman Generator starting problems
If you started it for just a minute, it never got warmed up and MAYBE the spark plug fouled. Check it first.
Sometimes one forgets where to set the choke for starting. And if engine is already warm from a short run they can be hard to start if too much choke is used and it floods... Again, when you check the plug, if it is wet this MAY be the problem.
To check fuel getting to the engine I have used an UNLIT propane torch into the carb to give an engine a mixture that it can run on without flooding. You usually have to remove the air cleaner to do this. That is a trick I have used for "cranky" engines.
Since you stired up the gas, the fuel filter may have got plugged.
Apr 16, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
Where can I get parts for Blue Max 6.5hp blue max
http://www.powermate.com/productmanuals.php?cat_id=3 for manuals and parts diagrams
Mar 16, 2010 | Coleman Powermate Powermate 5000W...
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Mar 12, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
345 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
