Question about Frigidaire Affinity ATF7000EG
I have an affinity. The washer will go through the wash cycle then it stops and says pause. It does not spin nor rinse. It is only three days old. What do I do?
I had the same problem. The water supply hoses were kinked. After I straighted them the problem went away.
Posted on Apr 23, 2010
I have the same problem. Let me know if you find the solution
Posted on Mar 27, 2010
This is happening to me too! Not sure of an answer yet... :(
Posted on Feb 10, 2010
Washer keeps pausing and now wont wash
Shelly,
I see that you're having trouble with your washer pausing and now not washing. I suggest giving the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If you are still having the pausing and no washing issue it might be something to do with the control board or possibly something else. I would suggest either calling the manufacturer or a local authorized technician. This way they can possibly troubleshoot with you and get this issue resolved.
-Best Regards-
Jan 17, 2014 | Frigidaire Affinity FAFW3801LW 27"...
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
Aug 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a ATF7000FS1 washer that has been pausing the wash cycle on it's own. I will have to press the start/pause button during the cycle to restart. This happens several times during a wash cycle. How...
some machine will stop before spin its called crease guard if you are useing a low temp cycle its there to give you the option to stop your cloths wrinkling try another cycle
Nov 08, 2011 | Frigidaire Affinity ATF7000E Front Load...
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
Need to know buttons to press to self clean.
Taken from the Use and Care guide:
To clean and freshen the washer, perform the System Clean Cycle. For best results use the System Clean Cycle once a month. To begin the cycle, press and hold the Spin Speed and Options buttons simultaneously for 10 seconds until the display changes to "CLn".
IMPORTANT
Items left in washer while performing the System Clean Cycle will cause a severe out-of-balance situation that could damage the washing machine.
REMOVE ALL ITEMS FROM WASH DRUM before filling the detergent chamber with one (1) cup of liquid chlorine bleach OR one (1) pouch of TIDE® WASHING MACHINE CLEANER. DO NOT use both. Press Start/Pause to begin.
If the System Clean Cycle is canceled or paused during the cycle, the washer will go through 2 rinse cycles to clean the drum of any residual bleach before unlocking the door.
Cheers!
Oct 29, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000EG Logo
109 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
