Question about Onkyo Audio Players & Recorders
Damage speaker right channel need to fix where i can find here in the philippines electronic shops accredited with onkyo
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Center channel stoped working on onkyo Dr-S2.2
Have you re-run the speaker definition and level steps? I can't find the manual. Perhaps you could flip a few pages in the Troubleshooting Section.
Posted on Mar 19, 2010
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
Onkyo 501 Onkyo Receiver no sound out of right
if you are good at tinkering then you can pulol the top of the receiver and check the fuses on the board to make sure that they did not blow if not then it would be wise to take it to a repair shop to have your receiver checked out and serviced
Dec 12, 2009 | Audio Players & Recorders
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
I need speakers for my Onkyo A-911M integrated amp
A+B speakers = 4 channels 2 right 2 left
100 watts/4 = 25 watts per channel
RMS watts / channel = 25 x .707 = 18 watts/channel which is your average consumer stereo system
I would use 8 or 16 ohm speakers (not 4 ohm) -- almost any set of stereo speakers will "work" -- these will be 8 ohm and about 5 watt minimum / 40 watt max thereabouts
May 07, 2009 | Onkyo Audio Players & Recorders
Right channel is out
If one channel is out, the output transistors are probably open rather than shorted. It is possible that there are other problems. If you have no experience with electronics, I would not suggest you start here. This is a simple repair for a shop and should cost about $20-$30 in parts (or less if not the outputs) plus the local labor charge.
Dan
Apr 01, 2008 | Onkyo TX-DS474 Receiver
please confirm that connection between your receiver and front speaker is ok(every thing is connected in right place no open cables.
please do setting again and make sure that front speakers are on.
Rear left channel not working on Onkyo NR801
Sounds as if it's time for a shop visit, unless you want to try this yourself. The panel connection on the rear of the receiver, or the protection relay have apparently come loose from the circuit board. It happens sometimes when stress causes the cabling to pull on the back of the unit..accordianman
Feb 16, 2007 | Onkyo TX-NR801 Receiver
74 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
