Question about Kenmore Dryers
Kenmore 110.86980800 Dryer making loud banging noise but works
My Kenmore 110.86980800 Dryer has been making loud banging noise while drying for months. We close two doors and can still hear it over the TV. Last night it stopped heating up cloths to dry them so we now hear banging all the time to get cloths dry with no heat. If If I replace the heating element with http://www.repairclinic.com/SSPartDetail.aspx?s=t-110.86980800-%3d%3di3367&PartID=3367 it should work loud again. Since our local Sears parts store closed down, What should I do to look for parts to resolve very loud noise problem. My wife is willing to live with the noise if it cost too much to repair. Also, where can I get a less expensive yet good quality heating element?
    New Friend:
  • 3 Answers
Try this link: https://www.searspartsdirect.com/model-number/11086980800/0582/0151200.html?searchType=modelSearch&q=110.86980800&searchTerm=110.86980800. Under Troubleshooting, click on "Making noise or vibrating". Most likely one of the dryer drum support rollers is bad. The parts bag will have two rollers so you can replace both of them while you have your machine apart. You will find the instructions on how to replace a roller by following the link on that page. Not a very difficult job. I didn't even have to pull the dryer out of the utility closet. Most time consuming part was vacuuming and wiping off everything inside. Went thru a lot of paper towels. The triangular retainers where a bit of a challenge to remove. I recommend some small needle nose pliers and don't worry about damaging these retainers since you get four new ones in the parts bag with the two rollers. The retainers go on both sides of the rollers and fit in a groove on the shaft. When putting the new retainers back on I used a 3/8 nut driver to initially push them on. A small regular screwdriver might also come in handy in getting the triangular retainers past the first groove. Only other surprise for me was the roller on the left side required the removal of a bracket held on by a type of washer retainer which worked on the pinching concept to remain in place. I ended up getting behind it with a small regular screwdriver, then moved it a little ways down the shaft. Then I grabbed it with some pliers and pulled it off. Wonder what engineer figured that one out. A new retainer comes in the parts package. Your dryer might vary a little bit (mine is a Kenmore 110.86873100 electric model) so take pics if you want. One other thing. I supported the front of the dryer drum with my dust buster while I took pics of the motor and pulley system before removing the belt from the motor shaft and pulley tensioner. I also used the dust buster as support when reinstalling the dryer drum. Good luck with the heating element. I haven't had to deal with that problem yet.
Posted on Apr 03, 2017
2 Suggested Answers
  • 88 Answers
SOURCE: Whirlpool Imperial dryer cyclic thermostate
there is a easyer way to check this put unit back together...put or had on back were vent blows hot exhaust air out...you should feel it get very very hot...then start to cool down..were you could put your had on the vent....if not replaced fixed tsat....please call if need more help..mike..843-384-8474...
Posted on Apr 03, 2010
Kenmore stackable dryer makes a loud banging noise whill it's drying. What is that?
The bearing and the rear and the drum slides need replacing. If you open the machine, you will find you can move the drum up and down.
Jan 22, 2017 | Kenmore Dryers
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Kenmore dryer model 76512694 works great but has a loud banging noise when drying
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 07, 2011 | Kenmore 75944 Gas Dryer
Repeat banging noise in dryer
Sounds as if the drum supports are bad. Replace the rollers that the drum glides on and should be good to go.
Feb 01, 2010 | Kenmore Dryers
Banging Noise in Kenmore Dryer
There are two rollers that hold the drum in place. I'm betting that one of those rollers have broken or fallen off. It's not a very easy fix since you'll have to take the dryer completely apart to fix it. Good luck!
May 25, 2009 | Dryers
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Loud noise
it may have a loose drum you need to call some one to have look at it and don't try and fix it on your own because it won't work
Apr 26, 2008 | Kenmore 74602 Gas Dryer
Dryer making loud and louder noise after about 5 minutes of use
my dryer started making a very loud banging noise when I turned it on. It heats up and the drum turns, but I am afraid to use it.
Apr 22, 2008 | Kenmore Dryers
Dryers Logo
297 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
