Question about Toshiba (MK8032GAX) 80 GB Hard Drive
Toshiba disc drive MK8032GAX Laptop will not recognise it anymore
Green light is on. disc seems to spin some times. Comptuer will not recognize it any more. If i reboot, the computer locks up. Once i unplug the USB cord from the the lap top, the lap top boots up. I have a memory stick and it reads it fine.
    President:
  • 281 Answers
My Toshiba px1394u-3g50 external hard drive is not working, light flashing and not recognised
Try connecting the hard drive to some other laptop and see if its getting recognized. Issue could be either with the hard drive itself of it could be with the usb port which you are using to connect the hard drive to your laptop.
Jan 17, 2012 | Computers & Internet
When the laptop is turned on, it only gets to the logo page which says In touch with tomorrow: toshiba. It does not boot at all, and only gives the options of hitting f2 or f12 for booting options, neither...
The problem is not with the battery or the AC power supply
( I assume you tried pressing F8 safe mode before the loading screen appeared?)
Get into the Bios by pressing ( I think its F2 or F10) as soon as the laptop starts up (before loading screen).
Check in the main page, that the laptop "sees" the hard drive. If it does not, then the hard drive has failed. (you can check this by substituting another drive and seeing if the laptop recognizes this in the Bios).
See also that the DVD rom is recognised
In the Boot order screen, check that the boot order is set to 1st boot DVD/CD drive and the 2nd is set to hard drive.
Using a windows install disc, boot to CD and see if windows wants to install (if the hard drive is recognised in the Bios but has an internal fault, Windows will tell you before it installs the OS)
If the drive IS recognised and windows installs ok, let it go to the 2nd repair option, where it looks for previous installations of windows and let it repair the system (your files will not be wiped)
If Windows reports that there is no HDD, then you should try a spare HDD and see if it will format and install .
At best, it sounds like the MBR has been corrupted, in which case the over the top install above should fix it, at worst, the hard drive has failed and will need replacing
Jun 19, 2011 | Toshiba Satellite A215-S4807 Notebook
My toshiba 80 g hard drive comes on but my computer cannot read it. Please advise..............Sagren
checking that the drive spins up and the drive is properly seated in the bay. try removing and putting back. then try to enter bios for confirmation it is being seen by the operating system.
if not then a suspect controller failure but don't rule out misconfiguration or jumper settings first.
Feb 18, 2010 | Toshiba (MK8032GAX) 80 GB Hard Drive
The DVD is not recognized by the computer.This is the 3rd time th
is it a burned disc,or does it do it with all discs,pull it out and get the make and model no. go to the manufactures web site and look for a firmware update for that drive
Sep 21, 2009 | Toshiba Satellite A205-S5879 Laptop
PC do not recognize DVD drive and do not show it on screen anymor
It is probably a hardware problem but I would go into the BIOS screen which it gives you instructions when your first booting up on how to do this. One inside the bios screen, which is usually blue, find a list of what hardwares are pre programmed in, maybe under drive managment. Almost all computers have different wordings. See if it listed amogst your hardware, if it is, it may be turned off some how, see if you can turn it back on.
Sep 08, 2009 | Dell Computers & Internet
Dvd rom not reading cds/dvds
I had similar problem on a Toshiba Satellite A30 laptop, I simply had to reconnect DVD drive. It usually loosing it's connection with motherboard and drive is visible in My Computer but it doesn't recognize any discs. If reconnection does not solve your issue you may try to update your DVD firmware and if it won't help replace DVD drive. Good Luck!
Mar 21, 2009 | Compaq Presario C700T Notebook
Doesn't recognize any disks
I updated my firmware from 1413 to 1416 found on avforums. This is for european units. I suggest you also complain to Toshiba Japan as there are known issues with the xs32. We all need a firmware update. See AVforums.
My unit will not recognise RAM discs anymore - even those that I had previously used.
Have you thought of replacing the DVD drive. See AVforums.
Oct 16, 2007 | Toshiba RD-XS32 DVD Recorder
Not copying program
Sep 06, 2007 | Toshiba RD-XS32 DVD Recorder
DVD RW / CD RW Drive
sounds as if your drive is failing, try buying a new drive.
Sep 03, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba (MK8032GAX) 80 GB Hard Drive Logo
599 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
