Question about Acer Aspire 5500 5570-2609 Laptop
After format - i cant load windows operating system.
after formatting my hard disk - when i re started the laptop i got this message no operating system found. i went to setup and selected cd rom for start up same problem.
how to go about this problem. please suggest some help.
    Genius:
  • 3,587 Answers
Hmm..ok...you need to go to setup, and change the boot order to CD then, hard drive, then something else, if you have it..
that should do it.
got backup for your Acer?
Posted on Feb 19, 2008
HOW CAN I TOTALLY FORMAT MY HARD DRIVE WHEN MY TOSHIBA SATELLITE WONT LOAD OPERATING SYSTEM?
All HD manufactures provide disk uility disks Find what type of hard drive you have and go to their web site download the disk and run it this should include a format uility For a sucure format download AUTOCLAVE burn it to disk and run it this one is slow but will put the hard drive back to a preformatted state
Mar 29, 2013 | Toshiba Satellite Computers & Internet
I have compaq nx6310, i had issues with the os.once you touch a button it starts open other buttons and pages automatically. i tried restoring the system to earlier dates and the issue reduced. later on it...
Hi das4real! These are the things to consider.
  • Operating system disk - Try to test your Installation CD to other computer. If it doesn't work then you need to replace the disk
  • Optical Drive (CD/DVD Drive) - If Installation disk works then try to clean your Optical drive lens as it may be having a hard time reading the disk. Your Optical drive is working since you're able to format and able to start the installation. Cleaning the drive lens may do the trick.
  • Hard Drive - If Installation CD and Optical drive is clean. Then the last thing you need is to replace the Hard Drive. You Hard Drive might need replacement due to some bad sectors and the installation couldn't write anything on the drive that causes to freeze during installation.
I hope this helps you.
Mar 15, 2011 | Computers & Internet
The screen is giving me a message that windows did not start successfully. A recent hardware or software change might have caused this. Dell Latitude d530 Thanks Mario
Hi,Most times this occurs when the Operating system is corrupt or if the Hard Disk is faulty,try starting in safe mode by pressing F8 when you power up the system and select "load last know Good configuration that Worked".if you still encounter these problem slave the hard disk to another system using a converter backup your files and format,reinstall the Operating system,or you purchase another Disk Drive.
Jan 02, 2011 | Computers & Internet
It is not formatting., please help me
hi
follow these instructions
Instructions Things You'll Need:
  • Windows installation media (and product key)
  • Manufacturer software
  1. Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
Nov 28, 2010 | Computers & Internet
How to reformat my laptop,toshiba satellite u 300.thansk
with what operating system?
There are two ways...
(1) take the hard drive out and connect it to another computer, right click on the drive, and click format
(2) You need a windows or other operating system disk....just start it like you were going to install windows, and select advanced disk options (it's a link, easy to overlook but it's always there)
You can not format a disk with a running operating system on it.
There are other "bootable" disks you can also format the hard drive with...an Acronis Backup boot disk, probably a Norton Ghost boot disk....things like that...not all bootable CDs, but usually a backup or disk imaging program will allow you to format a hard drive
Jun 15, 2010 | Toshiba Satellite U300-ST3091 Notebook
How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
Jan 05, 2010 | Sony VAIO Notebook
How i can format my laptop toshiba L300D can anyone tell me how to do it plz
If you have the windows install disk, just put it in and start a new install..there will be an option come up in the installation to format the drive.
If your laptop has a second hard drive listed that is very small that the recovery partition...go to it and run the recovery program
Aug 27, 2009 | Toshiba Satellite L300D-ST3501 Notebook
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Hard disk formetting
hi,
I think low level formatting should do the trick. you can download it and its free. In your case try to download the DOS based version. This type of formatting erases the entire disk clean.
Jun 07, 2009 | Microsoft Windows XP Professional
Error loading operating system
Firstly have you set your jumpers on your hard drive setting before placing into computer. If not check if the cd rom is on the same cable, if on same cable then change the jumper.
Have you gone into bios and loaded the hard drive. If a new hard drive you will need to detect it in bios first. Then Save and exit.
To go into bios, press f1 or f2 or DEL when you first start computer. Each computer is differentand you'll have to see which you require to press.
After bios is setup, put in your copy of windows xp, or your boot disks and follow instructions to set partition and format drive, then install operating system.
If you are only installing a new secondary drive as a backup, you will still need to detect in bios first. Then load you windows and go to my computer and format the drive using windows.
Aug 05, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
