Question about Whirlpool Dryers
My whirlpool dryer does not heat. I have checked the breaker.. what else can I do?
  • 254 Answers
Turn the power off,, remove the back of the dryer usually screws all around.... Check your heating element for breaks or damages,, check your thermostats there should be 3,, check your thermal fuse .
no heat on a electric whirlpool dryer is either an element, fuse, or thermosat. U can check all these with a metere for continuity. put one lead on each connection if it reads sometin it is okay if it reads nothin than it is defective and u should replace it....
if u like you can go to sears.com go to parts and service far right upper corner usually, go to parts,, then u should be in parts dirrect enter your model number usually on inside on sticker when open door this way u can get a parts breakdown and get part numbers and prices on potential parts hope this helps let me know how it goes bro good luck
Posted on Feb 02, 2010
  • 262 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
MAKE SURE YOUR VENT ISNT CLOGGED AND YOU HAVE 220 VOLTS AT THE DRYER IF ALL THIS CHECKS OUT GO TO ELEMENT WHICH IS BEHIND THE LOWER PANEL IN THE FRONT.REMOVE THE PANEL WITH THREE SCREWS ON THE BOTTOM AND TAP DOWN AND OUT AT THE SAME TIME. USE A VOLT OHM METER AND CHECK OHMS ACROSS THE TERMINALS OF THE HEATER IT SHOULD HAVE A OHM READING IF NOT CHANGE HEATER AND OPERATING THERMOSTAT GOOD LUCK
Posted on Dec 16, 2007
  • 1073 Answers
SOURCE: whirlpool electric dryer will not heat
check the thermal limit on the side of the heater housing and the blower thermal on the blower housing
the emement limit is at the top of the blower housing and will have 2 red wires going to it
the blower limit will have blue wires going to it
withe the power cord unpluged, remove the wires to these two limits and with a meter on rx 1 ect. read across each of these if you do not get a meter fluctuation , all the way to the right as you check the part os bad
Posted on Apr 12, 2008
projdoc
  • 2237 Answers
SOURCE: Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Posted on Jul 24, 2009
hiltonjug
  • 612 Answers
SOURCE: whirlpool dryer model wed5300sqo . unit running
There are a couple of part numbers you will need. If you will go to www.appliancepartspro.com and enter your model number. You will be able to see every part in your dryer. Now for whats wrong with it. This is a very common problem that I see at least 2 times during my business day. The parts you will need to check are as follows. Look at these parts on the diagram so that you can see where they are located inside your dryer
  • #7 AP3132867 Thermal Fuse
  • #9 Part #AP3094244 309 degree cut off plus a 250 degre high limit thermostat.
  • #15 Part #AP3131941 High Limit thermostat only.
Here is how to check these parts to see if they are good or bad:
#7 Thermal fuse/ Check to see if there is continuity between the two terminals on the part. If not, this part is bad. Replace. If it's good, check #9 the same way. Part # 9 comes with a part #15 also because if the part #9 is bad, it's because #15 had gone bad in the past and the dryer had been cycling off of #9 until it went out. Cutting the dryer heat off. One of the two parts #7 or #9 is bad. I hope this makes since to you. If your not able to test these parts, you can replace both and it will fix your dryer. Notice the prices are next to the part # on the web site. you can also order the parts from there, this is the best prices I have found. If I can help any more, just respond back. Good luck
Please rate solution.
Posted on Sep 08, 2009
  • 949 Answers
SOURCE: the dryer works but there is no heat
If the breakers are okay and you have power to the dryer the problem would be one of two issues.
The first and most likely is the thermal cut off. This is a small temperature activated fuse that will trip if the air flow through the heater is poor, this is usually due to a plugged lint filter or restricted vent pipe between the dryer and outside.
The second is the heat element itself has gone bad. You can measure it with an ohmmeter or physically inspect it for breaks. The image I have attached shows both. The T cut off is part 47 and the element is part 14 both visible with the lower panel taken off. The lower panel has 2 screws visible while laying on the floor looking straight at the panel.
The part numbers for the components are 279973 (cut off kit) and 3387747 (heater)
Posted on Apr 24, 2010
Whirlpool duet dryer will not heat.
Check your circuit breaker at the electrical panel first. It is usually 220v with two separate breakers. If one of the breakers is tripped, then it will not heat.
Mar 11, 2015 | Whirlpool Dryers
I have a whirlpool electric dryer.. when I turn it on its been having a problem with staying on or not heating at all. It will spin and stay on but no heat.we have changed the element and it seemed fi
Sounds like a tripped circuit breaker in the power panel for the house. The breaker for the dryer is actually 2 breakers connected together so if one trips so will the other. Sometimes this does not happen and only one breaker trips. This condition removes power to the heating element but still supplies power to the rest of the dryer. Check to see if the breaker will reset by turning off and back on several times. Then check the power receptacle that the dryer plugs into with a voltmeter set to read 240 volts AC. If no 240 but 115 is present then replace the circuit breaker.
Nov 19, 2014 | Whirlpool Dryers
I inherited an older model whirlpool electric dryer when I moved in...there seems to be no heat...went to get clothes out this morning and they were still damp...I wasn't given a manual - and have...
Check the breakers, by FULLY turning it off and then back on. What happens, commonly, is the heat side of the 220 breaker trips. If it keeps happening, sometimes you need a new breaker, but DO NOT increase the amp rating of the breaker. Breakers that trip from time to time, eventually start tripping EARLIER.
Jun 10, 2011 | Whirlpool Dryers
Whirlpool electric dryer not running.
Check the blown fuses and home's circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 21, 2010 | Dryers
Barrel of dryer turns but no heat
Your heating element needs to be replaced, or the 240 breaker in your breaker box has tripped. I was a maytag technician for several years...So, check your breaker box for any tripped breakers or the heating element in the dryer needs to be replaced, or the t.stat for the element has blown.
Apr 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
THERE IS NO HEAT IN MY WHIRLPOOL DRYER MODEL LEQ9030PQ0
Check the dryer twin breakers in the house electrical panel--push off, then on. If breakers hold, then try the dryer again. If it heats, you are good to go. If it trips the breakers again, there is a direct short in the dryer itself, usually in the heating element(s). The drum must be removed to access the element(s).
Sep 07, 2009 | Dryers
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer is not drying
the heater could be bad but you need a volt tester to check there are thermastats and thermal fuses that can stop the heat as well as the breaker the unit may run but not heat if one side of the breaker is triped or bad
Nov 29, 2008 | Whirlpool Dryers
Dryers Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
