Question about Zebra P110 CARD PRINTER 200 CARDS 1 YMCKO RIBBON SYNERCARD EXPRESS AND A DIG
Prints only part of the cards, leting a white stripe on the card
My fargo hdp600 keeps printing a white edge in the front of the card
please go to the print preferences and card there you will the card adjustment card size print width print length and card type are all there you can make your ajusment there and also patriot or lanscap
Mar 22, 2014 | Fargo Office Equipment & Supplies
My fargo printer prints black and white on the back of the card
Possible solution: Change the resin dither from Optimized for Graphics to Optimized for Photos with in the printer driver under the image color tab.
Feb 23, 2012 | Fargo DTC525 ID Card Printer
White Stripes on my printed card
The print head needs to be replaced.
Aug 09, 2010 | Fargo DTC525 ID Card Printer
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
When I turn the camera o a red stripe with white
Some cards have a lock tab on them. Make sure it is not in the lock position. If no go then take the card to a photo place and see if they can read it and download your photos. If that does not work then you can reformat the card (you will lose your photos). If you still are experiencing problems, try another card. If that does not work then it's off to the warranty repair or time to get a new camera. Repairs on these are only worth it if they are free or really cheap.
Jun 20, 2009 | Casio Exilim EXZ75 Digital Camera
Last month screen completely filled with gray and white stripes running from top right to bottom left. Turned off, and restarted. This happens several times weekly, whether on internet or not, using...
That is most likely the wrong video card for that motherboard. Or the video card slot on that motherboard is faulty... I would recommend taking it back to the shop and letting them fix it, since this happened after you got it back from the shop...
May 14, 2009 | HP vs17
HD Pavillion Media CenterDv8225nr Notebood Pc. Verticle stripes
I would try a couple of things. First and cheapest way is to try and update your driver. If that does not work, then try to remove and reseat your memory card(s), and if all else fails you will need to buy a new graphics card approx 75 to 150 depending on how good you want to go.
Feb 04, 2009 | IBM ThinkPad T21 Notebook
White horizontal stripe on top of screen
it is a repairable fault, you need to consult a technician for repair.
Dec 02, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Zebra P110 CARD PRINTER 200 CARDS 1 YMCKO RIBBON SYNERCARD EXPRESS AND A DIG Logo
13 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
