Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Guitar Amp wont power sound
My peavey guitar amp will not power sound
  • Allan Irvine
    Allan Irvine May 11, 2010
    There are a hundred different reasons for this.
    Is the amp fused and plugged in.
    Is the guitar directly inputed to the line in jack.
    A break in the lead can stop the signal.
    Is the guitar working with active pickups, a dead battery can stop them working properly.
    You need to be more specific.
  • Brandon Perkins
    Brandon Perkins May 11, 2010
    1. does the amp turn on?
    2. have you tried using a different cord from your guitar and amp?
    3. is the fuse on your amp blown?
    Problem Solver:
  • 10 Answers
Try checking the fuses.
Posted on Aug 04, 2009
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
Peavey 6505 plus buzz...even when all controls on zero and no guitar plugged in
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
Dec 27, 2013 | Peavey 6505+ 112 Combo Amp Combo
How to fix a gt5 peavey rockmaster amplifier
Hi. My name is Danielle and I have a peavey rockmaster GT-5 guitar mini amp, and it can work with/without the cable. I lost the cable and I didn't need to worry because the amp still worked as long as it had good batteries. But, after about 4 months of no use of it, I put in a brand new battery and the light wouldn't turn on. I looked all over the amp to see if something was missing but I found nothing. I'm really not sure what to do because this is a very good amp and I'd hate to throw it away. Can anyone Help Me?
Mar 24, 2012 | Peavey Electronics Peavey Rockmaster...
Peavey Vypyr 75w
If you hear any difference in the sound while moving the pot and not scratching sounds while moving it then its not the pot...
If i understood the problem right, i have seen it in 2 ELKA guitar amps.
In their case it was the TL072 opamps in the preamp section the problem and i tracked it and it must occured due to no earth connection in the wall socket and as a result to the amp...
Mar 11, 2012 | Peavey Electronics Peavey Vypyr 75 -...
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
May 30, 2010 | Peavey Valveking Head
My amp and cable are working... but my guitar wont make sound... when i turn up the amp it makes white noise... HELP!!!
PLUG YOUR LEAD INTO AMP TURN UP JUST A LITTLE SEE IF IT BUZZES WHEN YOU TOUCH THE END OF YOUR CABLE.IF IT BUZZES THEN THE FAULT IS IN YOUR GUITAR MOST LIKELY THE ACTIVE WIRE HAS COME OFF THE INTERNAL GUITAR PLUG.
Nov 04, 2009 | Peavey Music
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
Open Questions:
Car Audio & Video Logo
189 people viewed this question
Top Peavey Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
