Question about LG Washing Machines
Model WD 85260 NP donot switch ON from the front panel eft it for a few days it started again Now again do not switch ON
2 Suggested Answers
  • 6 Answers
SOURCE: our LG washing machine 5.5
IE on the screen of an LG washing machine can mean a lot of things.
1.It can mean that the washing machine can't fill up with enough water in 8 minutes time.
2.It can also mean that the water hose screens are clogged up with dirt and dust.
3.It can mean that you hoses are reversed. Your cold water hose might be connected to the hot water hose.
4.The water valves might not be screwed in completely.
If you need to reset your machine you can just unplug the machine and hold the start/pause buttons for a few seconds.
Posted on Jan 16, 2011
Testimonial: "I guess the 2nd point is applicable in our case.."
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
How do I change the drum to a Canon NP 7130 Black and White copier?
Could be the drum or the fuser causing your problem. To replace drum you need to open the machine by hitting the gray release latch on eft ide of machine to clamshell it open. Inside you will see th toner cartridge/ dv unit on the far right and immediately to the eft of that is the drum unit. You need to release the dv unit by turning a lever before removing the drum unit. Should probably call a tech to do this for you so you dont scratch or damage the drum. Drum life on that model is about 30,000 prints. Whats the meter reading on that copier?
Jul 25, 2012 | Canon NP 7130 Black and White Copier
LG WD 80260 NP washing service manual / circuit diagram
tE is heating error. Water not heating, Could be a faulty element, faulty wiring, faulty temperature sensor or faulty control board.
Jul 07, 2012 | LG Washing Machines
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
Mar 31, 2012 | Mitsubishi WD-60735 Projection Television
Our LG washing machine 5.5 Kg WD-85260 NP is having problem as it is showing IE on the screen and then stops. So we have to restart the machine again. What is IE?
Jan 16, 2011 | Washing Machines
We have a Mitsubishi tv Model WS48311 purchased in 2003. Recently the picture will blink off and then return on in rapid succession. The sound stays on when the picture is blinking. We hit the ?menu button...
You have bad switches on the front panel. Press them 50+ times to release them. Failing this you will have to replace them. You can disconnect the front panel to confirm this.
Jun 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
1998 Honda CB750 battery dead sometimes for no apparent reason
sounds like a bad charging stator circuit.  May be a bad rectifier or voltage regulator.  You need a multimeter to check each component.  It also simply could be a bad battery.
Mar 11, 2009 | 1998 Honda CB 250 Nighthawk
Euro-pro iron steam genarator model # ep8001
I have a temporary solution that is working: Use WD-40 around the switch. Spray with the straw that comes with the WD-40. Let stand for a couple days, then turn the whole unit upside down and spray again, and let it stand that way for a couple days. If we could get inside, it could be more of a sure thing, but I had given up on mine and when I accidently hit the switch after siting for the last few days, , it came on!
tombowdb
Now for Sears to try to locate the tool that will open the case.
Apr 17, 2008 | Euro-Pro Steam Generator EP8001 Iron
Washing Machines Logo
44 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
