Question about Husqvarna Sewing Machines
Have Viking Husqvarna #1+ sewing machine that when filling a bobbin caused the bobbin to overfill and break. Now when pressing the foot pedal the needle will not move. I can manually turn and get the needle to move but not with the foot pedal.
    Novelist:
  • 192 Answers
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
Posted on Feb 09, 2010
Husqvarna viking 300 sewing machine bobbin winder will not stop spinning. machine will not sew when foot pedal depressed. bobbin winder just keeps spinning.
The bobbin winder moves a plate next to the handwheel that disengages the needle from moving If you can't push it back to the left you will have to take the machine apart to fix it.
Jun 10, 2017 | Husqvarna Sewing Machines
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
What might cause my sewing machine to not respond when the foot pedal is depressed?
make sure the plug for the foot pedal is connected securely to the machine.
could be the plug in the machine has a problem even tho the foot petal is plugged in
could be the foot petal has gone out and needs to be checked.
Jul 27, 2014 | Husqvarna Viking 1
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
Dec 13, 2009 | Husqvarna Viking 1
My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Mar 14, 2009 | Husqvarna Viking 1
I hope I'm in the right place to find out where I can get the female plug and foot petal for a Viking Husqvarna #1 Thanks LindaB I have the elect plug but no foot.
Here's a link to the foot pedals one company offers:
http://www.sewingstyle.com/Husqvarna-Viking-Sewing-Foot-Control.html
Maybe you can use their generic foot pedal listed at the bottom.
Feb 19, 2009 | Husqvarna Viking 1
Husqvarna Viking #1 use same foot pedal as the #1+ ???
Yes it will work, you can go ahead and purchase it.
Jan 22, 2008 | Husqvarna Viking 1
Viking 1+
Your foot pedal plug is loose or possibly unplugged. You could also have a piece of fabric or thread that may be caught under the plate or around the bobbin. Remove all lint and oil the machine making sure the foot pedal plug is tightly in the machine.
Zelma
Aug 17, 2007 | Husqvarna Viking 1
Sewing Machines Logo
189 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
