I have a RA 4200. I have not used it for a couple of months. When I started to cut a master the machine stopped and gave me the add ink light. I pulled the cartridge out, it was about 1/5 full, but I replaced it anyway. The light stayed on. Also, when I close the door the door open light stays on. I get an E53 message.
  • 1 more comment
  • Tom Cockrell Feb 02, 2010
    The Russian help sheet did not help.. I read English only.
    New Info... the problem persists even if I change drums.
    Technical support at riso.co.uk is only for Riso Dealers and Techs.
    I'll give this a try and report back.
    Thanks
  • 542 Answers
There could be problem in the circuit of the catridge holders and door sensors as well. Need to repair the same with the help from expert engineers or service center experts.
Revert back for more assistance.
Posted on Feb 03, 2010
  • Rajesh Pai
    Rajesh Pai Feb 10, 2010
    I have not got any update on the issue. If your problem got resolved, please provide your valuable feedback/rating for the solution provided.
  • 767 Answers
Take the cartridge back out and clean the area where the cartridge goes inwith a q-tip and some alcohol. then put the cartridge back in and close the door and see if this helps. If this does not work unplugg the machine for a few minutes and let it sit then plugg it back in and see if this works.
Posted on Feb 02, 2010
  • 17,970 Answers
INSTALL INK CARTRIDGE
E 53
- Insert tube with paint
- Output when interruption of work:
  1. If the drive sensor tube is not pressed.
Also, here you can fnd more details about other error codes in startcopy.ru_codes_riso ; its possible that you needed use one "translator page" from russian to english.
Hope helps.
  • ZJ Limited
    ZJ Limited Feb 02, 2010
    Use this site to register,and then you will find all the Riso info you need: www.riso.co.uk
Bought new huskee 4200 last july, only been used a couple of time. tried to start it today and it turn over just will not start.is.th what wrong to new to be doin
My guess is you need some fresh gas. Also, I'm surprised the battery isn't dead. Lawn tractors aren't meant to be used "a couple of times" in 10 months. Empty the gas tank and fill it up with new high test gas. It wouldn't hurt to add a capful of carbuetor cleaner and to replace the fuel filter. If you run the battery down trying to start it, jump it with a car if you can get that close to it. As for everything in your post after "start", it might as well be Japanese or Icelandic!
May 15, 2016 | Garden
Riso ? One Stripe in the middle.
Yes you are right. The 'stripper finger' is not lifted enough so it scratches the master.
I know this problem from a GR. But the procedure should be nearly the same for your machine. Behind the back cover you will find a small rubber roller. Diameter 12mm (1/2") or so. This roller runs at the excentic curve of the drum. You might find that the rubber is worn of and so the finger cannot be lifted enough any more. You have to replace it.
(Hint: For a fast momentarily solution you may fix it by several windings of adhesive tape.)
May 04, 2010 | Riso RZ390 Duplicator
I have a riso 4200 and a 4900 that have been setting for a while, when I try to make a master it doesn't make all the copy it has white strips around the ink drum. How do I clean the drum so I can use them...
Since your machine doesn't used long time. This causes the consistency of the ink very loose and it will not go into the drum. Just replace with new ink and try to make several print by making several master and the pump unit will start filling it up. If you know how to go to service mode just use testmode 101. This will help to pump the ink inside by using just one cut of master.
Dec 31, 2009 | Office Equipment & Supplies
There's Not Enough Ink on the Drum, Wants me to add more
your ink fingers may need cleaning or replaced. your ink pump may be worn out. you should call a tech
Sep 21, 2009 | Gestetner Copier
I have a rotel RA - 820B x 3, that has stopped working.
Hi Nell. It is serious. Unless you are technically inclined, it needs to be checked out by qualified person. It will be fairly expensive to repair. Get an estimate.
Thanks
Paul
Jul 12, 2009 | Audio Players & Recorders
Adding audio to power point presentation
Try using this software
http://www.rm-mp3.org/
to convert the .ra file to mp3. Then you should be fine.
Apr 01, 2009 | Microsoft PowerPoint 2007 for PC
Installing lexmark 4200 series
If this is for the 4270 follow this link and select your operating. You'll be able to download what you need. If this solves your problem please rate this as fixed. If this is not your printer or you need further help just add a comment and I'll be happy to help you out. Thanks.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X4270
Apr 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
50 people viewed this question
jasbo
jasbo
