Question about Pelonis WM-HO202C Oil Filled Radiator Heater
Pelonis heater does not heat
It is plugged in but no heat nor is there a llight indicator on.. Am I supposed to put oil in it and if so where and what kind?
Thanks
    President:
  • 1,515 Answers
Hi, Have you checked to make sure that there is power at the outlet you are plugged into? I have looked up some information on this heater and it is in the top 5 oil filled heaters. I do know this, they are maintainence free. They are sealed and no place to fill will oil as the oil is heated to a certain temperature and not enough to burn the oil, so they never have to be filled. Anyway, check for power, and if you have power, check the cord over for any damage. If you can't find anything, you have a internal problem with the control on this heater. This is something you may want to take in to a appliance repair store and have checked out. There is no fuse to replace, so I would say a problem in the circuitry. There is not much for me to walk you through other then what I have mentioned, that it is getting power and cord is good. Please keep me posted.
Sincerely,
Shastalaker7
Posted on Feb 02, 2010
Testimonial: "They got back to me fairly quickly and although the problem was not solved. He did answer my questions. I believe it is a problem for a service repair"
My utility heater by Pelonis model hb301 serial no. 3011137160 will not heat up anymore .
the over temp safety switch has failed. It is replaceable but is a pain to change as they are usually attached with special high heat crimp terminals. there should have been a a warning light on the front that is supposed to warn you when the high temp switch has been activated.
Feb 15, 2015 | Pelonis Heating & Cooling
Pelonis oiled filled heater ho-0218 won't heat up
burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm. no you do not need to add oil, if the unit leaks throw it out.
Mar 24, 2014 | Pelonis Heating & Cooling
How much oil and what kind 1982 yamaha vision
It will take about 2 quarts. Don't you have a owners manual with your motorcycle?
Drain the oil, replace the plug, add one quart. check the dip stick, slowly continue to fill until you get to the proper level as indicated on the dip stick.
If you have not made friends with the guy or gal at the Yamaha Parts Department, you should go do that now. They will be a great source of information to you in the future.
Find and use your owners manual.
Thanks for your interest in FixYa.com
Feb 28, 2013 | 1982 Yamaha XZ 550
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
When plugged in no llights on modem motorola 2210-02
If there are no lights whatsoever illuminating when you have the modem plugged in to the electrical outlet, then this is going to indicate either a faulty power cord or a faulty modem. If you received this modem from your service provider, you may wish to contact them for assistance.
Aug 23, 2011 | Arris High Speed DSL Modem
What kind of oil does it use and where do you put it in?
Usually it is a mineral oil and it is supposed to be a sealed unit...there is no place to put in oil
Jan 22, 2011 | Lakewood Oil-Filled Electric Radiator...
Oil llight comes on but oil is full 1995 S420
faulty oil level sensor or wiring for oil level sensor, it's fitted at underneath the oil pan near the drain plug it's mounted to the oil pan by three bolt if you going to remove it you must drain engine oil first before remove the sensor, is this information helped you?
Oct 26, 2010 | 1995 Mercedes-Benz S-Class
Pelonis WM-HO202C Oil Filled Radiator Heater Logo
947 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
