Question about Samsung Computers & Internet
My Samsung 2493hm monitor quit working after a power surge. The power light flashes slowly but nothing else happens. Can it be repaired at a reasonable price?
  • showmetoo99 Mar 19, 2010
    I'm sorry it took so long to post my results. I replaced the capacitor and now my monitor works like new!!! The cost was less than $1.00 and took less the 40 minutes! Thank you SO much!!!
  • showmetoo99 Mar 20, 2010
  • 233 Answers
Dear showmetoo99,
Surely My Samsung 2493hm monitor quit working after a pow - favicon.icofavicon.icowiki-favicon-sharpened.pngoneriot-favicon.icoyou can fix it yourself with a very low cost.
I will explain how to:
  • Open the case of the LCD
basically in all LCD monitors have two circuit boards (power supply board and system board)
  • After you open you will see the two boards are
  • You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
  • Remove all cables connected to the board and take out the board. (get noted before you unplug it)
  • Now you see it components on board, we looking for capacitor.(see picture below)
    My Samsung 2493hm monitor quit working after a pow - 7a91ba9.jpg="h_mi">Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated (see picture below)
  • Replace the damaged capacitor with the same value that you can see on the surface of the capacitor. (In this step you need any soldering tool)
My advice: replace capacitors with higher voltage, like 10V replace with 16V or 25V will be fine.
Posted on Feb 02, 2010
Testimonial: "YES! I see the damaged cap! I'll replace it and let you know if the fix worked. Thank you!!!"
  • Deny Mulia
    Deny Mulia Feb 05, 2010
    nice, I was waiting for good news.
  • Deny Mulia
    Deny Mulia Mar 20, 2010
    So glad to hear that.
Hello, I have a Samsung 2493hm monitor, earlier this week I turned on my computer to see nothing. My screen remained black. The power button stays on and it never cuts off, so i'm thinking it's a...
With my Samsung 2493hn, I used HDMI. Use auto detect, on front next to secondary power. Not the main power switch on back of unit. Windows 10, click notification button lower right on Taskbar. Click on Project, then choose which option.
If when you power on Monitor without white squares with HDMI, ANALOG, DIGITAL printed in each then yes sounds like back light.
Aug 02, 2017 | Samsung SyncMaster 2493HM Monitor
It seems like im having some issue with my syncmaster2493 monitor. it will black out and once i wiggle the power cord it will come back on. any help will be apprecaited
Your power supply board is failing and when you wiggle the cord it is turning it on and off until it finally starts up. There are parts called capacitors that start failing and it will cause intermittent power issues such as slow to show picture, flashing power button, wavy or flashing picture. The board can be repaired and the monitor will be as good as new. Here is a picture of the power supply with the parts circled that need to be replaced.
There is a step by step repair guide for the Samsung 2493HM unit here:
http://www.ccl-la.com/blog/index.php/reparing-a-samsung-2493hm-24-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 30, 2011 | Samsung SyncMaster 2493HM Monitor
Samsung monitor 2493HM wont power up I plugged it it and the blue light came on for about 5 seconds then went out and I havent been able to get it going again.
The Samsung 2493HM monitor are known to have an issue with the power supply. When the power supply fails you get the 'no power' or 'slow to show picture' problems like you are having. The board can be repaired and the monitor will be just like new again. This is what the power supply board looks like:
Here is a link to a free repair guide that will walk you through the repair.
BuddyMc
Jul 02, 2011 | Samsung SyncMaster 2493HM Monitor
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
My Samsung SyncMaster 2493HM Monitor has trouble starting. When my monitor has been off for a while and I restart it. It makes a little beeping sound and the little light on the right bottom of the screen...
The Samsung 2493HM monitors have an issue with power supply failure. When the board starts failing can be slow to show a picture, have no power at all or have a way or flashing picture. Your monitor sounds like it falls in the slow start category. The power supply board can be easily repaired and the monitor will be just as good as new. Here is a link to a free repair guide that will provide a step by step instructions showing you how to disassemble the unit, check and repair the power board.
BuddyMc
Apr 13, 2010 | Samsung SyncMaster 2493HM Monitor
I have a Samsung Syncmaster 2493HM monitor. The problem is it seems to work when it feels like. The monitor will stay blank when i start my computer up. The power light will flash quickly, to my...
Your power supply is going out. LCD monitors have a common issue. The heat buildup in the in the cases cause parts called capacitors to overheat and bulge. When they bulge out the don't operate properly and cause the power supply to not start up correctly or not at all. First thing check the warranty, Most Samsung units have a 3year parts and labor warranty. If it is out of warranty then repair it yourself. If you can solder then you should be able to do the repair yourself. Check out our web site at:
www.ccl-la.com We don't have your exact monitor but you should be able to look at other Samsung guide we have posted and see the parts that need to be replaced. Open your case and replace any capacitors that are bulging and you should be back going again. If you don't want to do the repair yourself we do offer a repair service for you unit, check our site for details.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 03, 2010 | Samsung SyncMaster 2493HM Monitor
No picture; no operation except flashing blue lcd light.
Look at the power supply first, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 30, 2009 | Samsung SyncMaster 2493HM Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Computers & Internet Logo
1,830 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
