Question about Panasonic AG-1980 S-VHS VCR
Colour Noise and Dim Display
I have a Panasonic AG-1980 I use for the home; pretty expensive investment so I hope I can rescue it. Playing back VHStape shows wavy diagonal red & blue stripes on the screen. S-VHS tapes are considerabley better, but still show fine interference patterns. VHS recorded on it seem to play back on other machines fine. Last year, the front panel display worked well only part of the time. When it worked at full brightness, I could hear a high-pitched capacitor squeal, now the display is very dim and it needs to be in a very dark room to be effectively used. I have the full service manual. Panasonic AG-1980 VCR. Seems to have two problems, Dim display and when the tape gets to the end of the cartridge it doesn't go into rewind. The unit freezes up won't eject the power goes off. What do I need to replace?
    Brigadier General:
  • 3,614 Answers
Did you try cleaning the tape head of the player?
For some reason be sure all the gear or any mechanical inside the player is freely rotating.
Adjust the VCR tracking to get a good picture.
Posted on Feb 19, 2008
2 Suggested Answers
  • 221 Answers
SOURCE: Colour Noise and Dim Display
The display on the AG-1980 goes dim mostly from old age - replacement of the display usually cures the problem, though you may need to replace some or all capacitors in the power supply. The diagonal stripes are usually caused by a defective video amp/filter IC on one of the video boards. If they are still available from Panasonic, they're about $40.
Posted on Jun 29, 2007
Panasonic AG 1980, displays d u 10, ejects tapes
It hates what you have put into it. OBB SEEN
Apr 23, 2014 | Panasonic AG-1980 S-VHS VCR
Was looking to buy one, and before the seller
the tape deck has jumped timing and can cost 40 to 100 dollars depending on how quick it takes the tech
Jan 05, 2010 | Panasonic AG-1980 S-VHS VCR
Video noise pattern in playback panasonic AG 1980P VCR
It sounds like the video heads are dirty, or the tracking is off. I would first try adjusting the tracking to see if it can be corrected. If that does not work then I would clean the video heads using a video head cleaner (Radio Shack) You could also try a different tape to see if it that could be the reason. Also double check you video connections to your monitor to make sure they are good. If all of this fails than it may have to be checked out at an authorized Panasonic repair facility!
I hope this helps and good luck!
Nov 12, 2009 | Panasonic AG-1980 S-VHS VCR
No power. led display very dim
dim display on an ag-1980 may be caused by bad display module or bad electrolytic capacitors in the display power supply. "no power" is probably a bad 12 volt regulator on the main board. the main power supply is working as evidenced by the display lighting up.
Jul 03, 2009 | Panasonic AG-1980 S-VHS VCR
The main light on the front panel went out on my 1980 desk editior. how much to repair?
Jan 22, 2009 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980 Wont load cassette
probably caused by the mechanism being mis-timed. re-timing isn't difficult, but a service manual is absolutely necessary.
Nov 16, 2008 | Panasonic AG-1980 S-VHS VCR
H02 Error Message
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Apr 02, 2008 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980
most likely problem is a dirty or defective mode switch. this switch tells the internal computer what position the mechanism is in. if the switch is bad, the computer is "confused."
Sep 24, 2007 | Panasonic AG-1980 S-VHS VCR
you may have a slightly damaged power supply...although swapping the main supply chassis may solve, I have seen front panels that have an additional supply section. look on the front panel board for any TP's and probe with an O-scope. if you see a TP that may also show (+ xx V), where xx is a numerical value-may be one x only, the scope must show a straight horizontal line that is shifted vertically away from its normal (ground) position. that confirms a DC value present. then determine the DC value of the shift. Another possibility, since you invested, is to search ebay for a second unit for part swapping. look for as-is units.
May 27, 2007 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980 S-VHS VCR Logo
286 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
