I have a Huawei Echolife HG520b/s Router Which as username and password Iwant to Reset.How Do I Reset The Router
  • eric396 Feb 02, 2010
    Thank you Michael for your quick responce
To reset your Huawei Echolife HG520b router, the default username and password are both admin
http://www.talktalk.co.uk/help/broadband/connect-wirelessly-with-a-huawei-echolife-hg520bs.html
Posted on Feb 02, 2010
How to update sagem f@st 2804 stc modem
default STC password for Echolife HG532b a.k.a. Afaq shamel 007 :
address: 192.168.1.1
username: Afaq_Shamel
password: Stccpe_2009
for Echolife HG532b
Jan 24, 2013 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Router modem-CAT5 adaptor
does this router have a lan1 lan2 lan3 lan4 ports ?
the adsl port may be for a phone line so you may need to turn off the ADSL functions in the Huawei Echolife HG520s router . Turn off the DHCP server and then plug connect lan1 to your office network. Change the ip address to be unique in your office network ip network range.
maybe 192.168.0.2 if office router is 192.168.0.1 subnet mask made the same .
Jan 30, 2018 | Computers & Internet
HUAWEI Echolife 520b Password
IF YOU CAN NO LONGER ACCESS YOU ECHO LIFE ROUTER WITH YOUR PASSWORD YOU MAY NEED TO RESET THE ROUTER AND START AGAIN FROM SCRATCH.
THX
Dec 26, 2011 | Cell Phones
I am trying to connect an ASUS F5VL laptop with a Huawei EchoLife HG520b router but the Atheros AR5007EG adapter is not recognising any wireless networks. I was previously able to install the network...
Cycle both, meaning turn both wireless radios off then on, which might mean unplug the router and reboot the laptop. Try again. If nothing, make sure the router is set to broadcast the SSID by going to 192.168.1.1 and using the web interface to the router. Check those other settings and make sure your wireless is enabled and all. Also, Vista likes to corrupt wireless settings, so if the connection is already saved, remove it from Vista's wireless list of preferred networks and start again from scratch.
Mar 17, 2010 | Computers & Internet
U Torrent port is not open since changing from a modem to a router its a Huawei Echolife HG520b type router.Torrent page is showing a red symbol,not green for faster downloading.The fire wall has U Torrent...
See the link below.
You should find this page on your router configuration where you can configure which port is open for which computer.
Its virtual server for your router. Look for NAT under Basic settings.
http://portforward.com/english/routers/port_forwarding/Huawei/EchoLife-HG520b/BitComet.htm
Jan 11, 2010 | Computers & Internet
Huawei
Hi1 By default huawei hg510 uses ip as 192.168.1.1. Now open your web browser and enter this address or under run(from start menu) enter this ip address. Now under user settings or advanced settingsthere will be an option of password reset. You will not have to reset the modem but the password. Now it will ask for a key. the key can be found out on the back or on the base of your modem. Hope it resolves your issue
Dec 27, 2008 | Computers & Internet
Forgotten pw
There is no way to access the router without resetting it. You must reset the router, and make a new username or password. Sorry!
If you want, the only setting you need to set is to change your local IP address to 192.168.2.1 (IF you have DSL.)
Please can you tell me how to setup a huawei EchoLife HG520b Broadband wireless router. Thanks
You need to follow the below steps to enable you to go wireless, connect your PC and Router via the Ethernet cable.
1. Open any web browser and in the address bar type 192.168.1.1 and press Enter.
2. You will now get a login screen appear, the username and password to access the router is " admin "
3. Click on Basic then Wireless LAN.
4. Make sure Access Point is set to enable.
5. SSID is your Network name and can be changed to anything you like.
6. Make sure Broadcast SSID is enabled.
7. Set Authentication type to WPA
8. Set a password in the Pre-Shared key section between 8-64 letters/numbers long-this is your wireless password, keep this safe as only you have access to this password.
9. Click submit at the bottom of the page.
Your router has now been setup for wireless and is protected by WPA security.
To Allow your PC to connect wireless:
1. Remove your ethernet cable and turn on your wireless on your PC.
2. In the bottom right hand corner of your PC right click on your wireless icon and select "view wireless networks in range"
3. You should see your wireless connection because the SSID should be displayed.
4. Right click on your network and enter the wireless password and then click connect (If right clicking brings up no options then double left click).
5. You should now be connected in a wireless state.
To Allow your MAC to connect wireless:
Please first update the MAC, click the apple top right and update software.
1. Remove your ethernet cable and turn on your wireless on your MAC.
2. Top right click on the airport icon.
4. Click on your network and enter the WPA password and then click connect.
5. You should now be connected in a wireless state and the airport icon will turn black.
If you have not yet entered your ppp details (username and password for internet connection) select basic and then wan settings you can change all the settings for your connection here
Hope this helps
Nov 06, 2008 | Computers & Internet
Cannot connect ds to wireless router - Huawei Echolife 520s
Ensure that the B type is enabled in your router and that the security it set to WEP and that your passcode is correct.
HTH
Oct 27, 2008 | Nintendo DS Lite Console
Computers & Internet Logo
526 people viewed this question
David Payne
David Payne
