Question about ViewSonic VX2235WM Monitor
Black screen The monitor is a viewsonic VX2235wm. It powers up but it has a black screen. I connected the PC to another monitor and it worked fine. The Viewsonic monitor worked fine when I cut it off and when I restarted the PC the next day it never came up, just a black screen
  • 11,361 Answers
Look in the power/inverter board for bad caps with bulging top first, post back what you see inside so we can you further, see failed VIEWSOINC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 15, 2010
Viewsonic vx2235vm does not turn on
This really sounds like you have a power supply board that is having problems with the filter capacitors which are causing it to not start up correctly. Here is a like to a repair guide including video instructions showing how to open and repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
Part one of the video guide:
Feb 07, 2013 | ViewSonic VX2235wm LCD Monitor
Hi, I have a ViewSonic VX2235mw LCD Monitor it was working fine then all of a sudden the screen turned off and now it wont turn back on. The power light is on and is Blue but no sign of life in the screen...
This is a very common problem with this model after a few years of use. This problem is caused by a failure of the capacitors in the power supply board hat powers up the back lights in the monitor. When the back lights don't power up you get no display on the screen. Here is a link to a repair guide for that model that shows how to open the unit and what to look for and replace to repair the monitor.
Here is part one of the three part video repair guide posted at the above link:
Jan 29, 2013 | ViewSonic VX2235wm LCD Monitor
No power to vx2235wm. How can I fix it?
Black screens or no pictures are usually caused by a failure in the back light power supply. Many times the monitor is working but with the back lights not turning on you can't see the display. Here is a link to a repair guide that will show you how to open the unit and what to look for and replace to rebuild the power supply and bring the unit back to life.
I hope this helps, if so please rate my solution.
BuddyMc
Dec 07, 2011 | ViewSonic VX2235WM Monitor
How to open a viewsonic vx2235wm monitor?
Here is a link to a repair guide with pictures and videos showing how to open the unit and then repair the power supply board that is the most common cause of issues in the VX2235wm monitor.
BuddyMc
Nov 14, 2010 | ViewSonic VX2235wm LCD Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
Viewsonic monitor -- VX2235wm LCD
avintagedish, Possible problem w/unit power supply. Go trade it in on new a new wide screen so the electronics technician in the repair area of the store can (with a little luck) put less than $10 in parts into your unit and maybe have a nice VX2235WM to give to his 10 year old kid to play games on. I sure hope you have a valid warranty!! You should verify that VX2235WM does same at KNOWN GOOD pc!!! Swap-in a KNOWN GOOD monitor to prove pc is OK!!! Read my FIXYA profile and learn "flashlight test" for "rude an crude" test of "switch-mode-power-supply" status. Follow the links you find there to other web sites for more info. Check to see if ViewSonic has a cash+old swapout for factory refurbished unit for premature failed units! I'm lmistyrel over on aim. and 12fixlouie on FIXYA good luck in your quest to fix unit. It can be fixed. Just do your research FIRST! So you don't get ROOKED if you contract out the work. Read, read, and read some more!! Visit YOUTUBE for video clips of LCD monitor repair and disassembly. FYI.
Bye for now.
Feb 05, 2010 | ViewSonic VX2235WM Monitor
I have a ViewSonic VX2235. No picture at all
sounds like a burnt or a cold solder around the TRANSFORMER section of the power supply , I suggets if your handy w/ tools to open the monitor and inspect the PC BOARD for any burnt or cold solder THAT not making the connection , hope it helps AJ
Nov 09, 2009 | ViewSonic VX2235WM Monitor
ViewSonic VX2235wm monitor looses power ...
I've not seen this problem on a ViewSonic but have on a Dell flat screen. The fix was the obvious one: the power connection on the back of the monitor was loose -- have you checked this. Also if the power cord is too tight it could be the problem. Other then this, it sounds like a short inside the monitor.
Hope this helps
Mar 17, 2009 | ViewSonic VX2235wm LCD Monitor
hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
Sep 08, 2007 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235WM Monitor Logo
695 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
