Question about Roper Refrigerators
Hinge holding large bottom door has come off and door came off
    President:
  • 1,218 Answers
Good day,
You will have to remove the freezer door first. Save all bushings and spacers as you go along.
Remove the top hinge first, then lift the freezer door off.
Next remove the center hinge.
You will need to determine what happened to the bottom hinge.
It is usually bolted on with either 2 or 3 bolts. As well it has a pin inserted into it that points up.
After the bottom bracket is bolted into place properly, with the pin sticking up, you place the main door on the pin,and close the door.
The next step is installing the center pin, which is held in with screws as well. Make sure the door is aligned, then....
re-install the freezer door.
Posted on Feb 02, 2010
How to remove bottom (freezer) door on my subzero refrigerator/freezer
With the door closed. Remove the cover over the bottom door hinge by removing the two screws holding it in place. This also allows the door closing mechanism to be removed. Rotate the door closer away from the refrigerator and slide straight down. Now open the freezer door. Take a pencil and mark around the hinge on top of the freezer door so you will know where to put the hinge back in place later. Remove the three large hinge screws and two small shipping screws. This will release the door on the top. Rotate the door away to get free from the hinge and pull the entire door straight up.
Dec 08, 2013 | Refrigerators
Tip
How to Reverse Your Refrigerator Door (Most units)
1. Remove the toe grille.
2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside.
3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin.
4. Lift the refrigerator door off of the bottom hinge and set aside.
5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws.
6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge.
7. Remove two screws on bottom hinge with 3/8" socket wrench.
8. Install bottom hinge on opposite side with the two screws removed from Step 7.
9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench.
10. Reverse door handles.
11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam.
12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole.
13. Tighten center hinge pin with adjustable wrench.
14. Remove cabinet and hinge hold plugs and move to opposite side.
15. Lower freezer door onto center hinge pin (if you have a separate freezer door).
16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge.
17. Flip top grille and reinstall.
18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
on Oct 19, 2011 | Frigidaire Refrigerators
How do I change the door from one side to the other on my Zanussi ZNB 38 NDX?
The door comes off a set of hinges. You may have to remove the front fascia at the top, and access the screws holding the top hinge on to the frame. Unscrew these and remove the door by lifting off the bottom hinge. With the door off you will be able to remove the screws holding the bottom hinge. If you are lucky, they will reverse fit to the other side as they are. If not, use what was the top hinge as the new bottom hinge, fit the door and use the bottom hinge as the new top hinge.
Jun 09, 2012 | Zanussi Refrigerators
Right door no longer closes all the way by itself
If you're loading up the door with a large amount heavy items such as gallons of milk, water, juices, etc. - the door may be sagging on its hinges.
Typically, there are several screws that hold the top and bottom hinges to the fridge frame. While supporting the weight of the open door with blocks or books, check to see of the screws have loosened up or if the hinge has slipped on the fridge cabinet. It may be helpful to partially / fully unload groceries / liquids from the door.
You may be able to detect that something has happened if there is space between the top hinge and door. This suggests that the door has slipped slightly and may be rubbing on something. Look for scrapes, scratches and filings in the area of the bottom hinge. These are a tip off that something has changed. Try lifting the door up. Is there "play" between the hinges that allows the door to slide up and down? A little bit is normal, but too much indicates a sagging or bent (not common) hinge. You may have to lift and support the door to take up the "play"; then loosen the bottom hinge's screws and slide the hinge up until it is snug against the bottom of the door. Tighten the screws firmly to hold the hinge in place. This should lift the door back to where it was (or close to it) and prevent any rubbing or scraping that may have been happening before.
Lastly, make sure that the doors seals haven't shifted or become damaged in such a way as to interfere with the door closing completely. Good luck!
Feb 14, 2012 | Frigidaire FRS23R4A Side by Side...
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Changing the opening side of the door
You will need to reverse the hinges, it should be the top for the freezer, and the one in the middle support, both the freezer and the large door, you will not only move this to the other side but you may have to turn it over, and the bottom hinge just move it to the other side. You will need to start with the large door, because the hinge support the bottom and top door, the bottom first, next the middle hinge, place the freezer door on the middle hinge and the top hinge to sesure the freezer door, move the handles, the holes for the screws will be on the other side with a little cover that you will have to remove just have to pull them out.
Nov 25, 2009 | Maytag MTB1891AR Top Freezer Refrigerator
My frigidaire microwave door is sagging and is about to fall off
EASY get a machine screw, nut with washer. I believe I used a 1/8" machine screw.....(find something small to fit in the hole on the bottom hinge.
First step, take 3 screws off bottom to expose hinge area. Have someone hold it or support it so wires to the light do not pull out,.
Pop the machine screw through the front and then with your fingers get the washer an nut and tighten down.
If you want the professsional look. Paint the machine screw white first with a enamel white paint.
Sep 03, 2009 | Frigidaire PLMV169DC Microwave Oven
How do iremove the doors on my conquest
Remove the hinge cover at the top for both doors . Remove the bottom kick plate from the fridge . On the freezer door , follow the white tubing at the bottom about 6" to a connector . Remove the hose from the connector . Unplug the receptical at the top of the freezer door and remove the 3 screws from the top hinge . Lift the door upwards , pulling the bottom tube thru the bottom hinge . For refrig door , just remove the 3 screws holding the top hinge and lift door off bottom hinge . Hope this was helpful .
Aug 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bolts broke on bottom drivers door hinge
a vw wreckers or dealer will sell you the correct hinge bolts with the year model on you
Nov 08, 2008 | 1998 Volkswagen Beetle
Oven door not closing correctly
I had the same type of problem. I unhinged the door then disassembled the door (it's really quite easy)
after you take all the TORX screws out the everything comes apart! Don't worry about the screws putting them back is a snap! Now that you have the door apart take the door hinges out of the inner door plate.
If you look at then closely they will have a slight bend in them. Pay attention to how they would have been positioned on the door! Simply bend them slightly I used the edge of a step! My door now shuts completely! I hope this info helps many of you having the same problem! If you take the time it really is amazing how easy it is to solve the door issue! Thanks to my buddy RON.
Aug 06, 2008 | Bosch HBL 435 Stainless Steel Electric...
Refrigerators Logo
74 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
