Question about Hunter 33201 Humidifier
The fan is not turning to pull the water into the system but you can hear it running
Brand new humidifer i can hear the fan working but the water is leaking all over the floor the water tray is filled and the tank is empty
Posted on Apr 11, 2010
We just bought a house with an existing Aprilaire 600 humidifier. It is now heating season and we ae running the furnace. I turned on the humidifier and no water is getting to the pad.The water line is ok...
Hello,Make sure the heating blower/fan is running when you turn the dial as the humidifier might not have power if there is no heating blower operation.
Nov 06, 2010 | Aprilaire 600 Humidifier
House is dry though it's quite cold outside and furnace is running. Aprilaire is turned up to 35 (I have a dial, not a digital panel). the water panel is completely dry (should it be?)
unless the humidty in your home is higher then 35%. if it is then the humidifier would not run. try turning it up higher and see if it comes on. Do you hear a click in the humidistat? as you turn up the dail when you hear the click is when the humidifier should come on. Also remember your furnace must be running for the humidifier to come on. if you hear the click and the humidifier fan comes on but no water, you may have a clogged inline filter located in the solinoid valve or a bad soliniod. all parts for your humifier can be purchased from www.aprilaire.com
Feb 05, 2010 | Aprilaire 700 Humidifier
It does not turn on with the furnace. the aprilaire fan does not click on and there is no water running through the system
Hi check the stat and see if the water feed is not blocked at the jet seeif you have water to the valve
Dec 22, 2009 | Aprilaire 700 Humidifier
Water is running thru inlet pipe but does not seem to come out of the outlet. I am unable to detect any clogging
There is a strainer that is on the inlet side of the solenoid valve you may need to pull it out to check if it is clogged. Also when you have the humidistat turned all the way up do you hear the solenoid click and the fan inside running
Dec 13, 2009 | Aprilaire 700 Humidifier
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
My Aprilaire 700 does not seem to be working. The
you can bypass the humidistat by shorting the 2 brown wires on the bottom of the humidifier. just remove the 2 wire nuts and touch the 2 together (just 24v)if it comes on then there is a control problem with the humidistat or wiring if it doesnt come on the control board or transformer may be bad or you dont have 120v to the humidifier on the plug. also make sure your furnace blower is running cause the hum cant come on if its wired properly unless the fan is running. you also may want to go to www.aprilaire.com and get a maintenace kit from their online store. it comes with pad and new hose along with a couple other things.
Nov 24, 2009 | Aprilaire 700 Humidifier
My honeywell humidifier attachment on my furnace will not start after the summer with water running to it.I have the humidity cranked up, but the filter is still bone dry.
Humidifiers usually are wired up to ONLY come on when the Heat is on and the fan running....anyother time you check it it will not be powered or wet...turn your heat on , wait till the fan comes on...then turn up your humidistat you should hear a click if its a flow through type and water should start flowing from the top...or if its tyhe drum style with the sponge...you should see it then turning...if it doesnt turn the pad/spindle may not be installed properly...if only fits one way
Oct 24, 2009 | Honeywell Power Humidifier: Furnace...
Fan running but no water flow
the humidistat on this unit just acts as a set of dry contacts. with the humidifier plugged in, you should be able to touch the 2 brown wires by the water solenoid together and get the power fan to run and the water solenoid to enrgize. if you do this and water does not flow, you most likely have a bad water soenoid. it is either electrically bad, or just plugged with water deposits. sometimes you can pull it apart and clean it, sometimes you just have to replace the solenoid.
Jan 26, 2009 | Aprilaire 700 Humidifier
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Aprilaire 112
Kurt, a couple of things you can check. First when you turn the humidistat do you hear a click from the solenoid? This would indicate that you are in fact getting power. Check the saddle valve from the supply. Turn it in and out to make sure it is not clogged. You should have a inline strainer on the inlet side of the valve. Make sure it is not clogged with deposits. On the discharge side of the valve should be an oriface, make sure that is clog free. If you have an meter you can check for power at the soleniod or pull the harness off and ohm it. Should show continuity. Catriver...post back.
Oct 15, 2006 | Aprilaire 1120 Humidifier
Hunter 33201 Humidifier Logo
255 people viewed this question
Top Hunter Humidifiers Experts
Vernon Taylor
ka4iup
ka4iup
mike
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
