Question about Emerson TC1351 13" TV
Emerson TC1351 Chassis Power Switch
Does anyone know where I can get a used or inexpensive internal part of a chassis power switch for an Emerson TC1351 or other model that would work?
  • Emerson Master
  • 5,138 Answers
As cheap as 13inch tvs are why do you wont to fix it , I sell nice used 13inchs for 40.00
Posted on Feb 19, 2008
  • ladywinn
    ladywinn Aug 04, 2008
    I still stand by my answer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
How to test to see if the wiper switch has power on the acura tl
You can work backwards, too. Get a test light (they're inexpensive), connect the clip to the car's metal chassis, and poke the wires on the wiper motor. If you find power, the light comes on. If you get power on both wires, then the ground isn't connected. If you don't get power on any of the wires, then get to the switch, and do the same test....
Yes, it's a pain, but that's what mechanics get paid to do.
May 15, 2015 | Acura Cars & Trucks
Tip
HP desktop power-supply LED lights, but system shuts off/hibernates during...
The "Problem" section below describes a startup problem my 9-year-old HP desktop developed last week. You may be seeing similar behavior in your HP desktop, or even in another brand. The "Solution" section describes a simple fix (cost: ------
Problem:
Our HP Pavilion a220n tries to start up but turns itself off or sometimes hibernates in the middle of booting up. Although I got it all the way to the login screen once, it then shut off again. It is not stable enough to use or to copy our files over to a new PC.
I've eliminated as causes the power supply and the AC cord. Because sideways pressure on the switch assembly can cause the problem, I assume I need to replace the switch. The faulty power switch is HP Part # 5187-2439 and includes a plunger microswitch, 2 LEDs, 12" cable and motherboard connector. The power switch assembly doesn't seem to be available from HP or third-party sources after 8-9 years -- big surprise!
The FixYa suggested solution with 2x5 motherboard pinouts is the beginning of a solution to my specific problem. Those pinouts do match the pinouts for my switch assembly. If generic power switch assemblies matching this pinout had been available, replacing the assembly would have solved my problem.
Solution:
SOLVED by replacing a noisy power-on/off pushbutton. Of course, you should observe all typical precautions to avoid electric shock to yourself or static discharge to PC internal circuit elements. Wearing a grounded wrist strap and touching the chassis metal to a grounded lead will help with this.
To start, you must remove the "bezel" (front panel) from the chassis after removing both side panels. Instructions for doing this are embossed on the plastic mounting flanges, and you can also access online instructions at the HP site. There's a small (about 1" by 2") plastic housing for the power switch, power-on LED, and disk-access LED, that you pop out from the chassis, making the switch contents accessible.
For convenience, I unplugged the 2-by-5 plug from the motherboard and worked on the switch assembly outside the chassis. To thread the plug and cabling out of the chassis requires removing the hard drive from its mounting bracket (no screws) and the mounting bracket itself (two screws). You may be able to do the repair without this step.
Then I verified with an ohmmeter that the original pushbutton was a single-pole, single-throw, normally open (SPST, NO) momentary switch, which closes the contact only as long as it is pushed in. It really had to be that type, considering that the switch has just two wires coming off it, and that depressing and holding the pushbutton has a different function from depressing and immediately releasing it. Checking with an ohmmeter also allowed me to verify that the switch was noisy (it intermittently closed when the plunger or housing was laterally stressed). These intermittent closures were causing the spurious hibernate events.
I bought an inexpensive replacement switch of the same type (in mini-pushbutton size, part 275-1547) at the local Radio Shack. As of today (6/16/2012) it is listed online at "http://www.radioshack.com/product/index.jsp?productId=2062539". Although the online site says it is rated at 0.5 A, the package says 3.0 A at 125 V. Any other similar switch would do as well.
In my HP model (HP Pavilion a220n), the pushbutton lives in a square hole in the 1" by 2" switch/LED mounting piece mentioned above. It is easily poked out with a pointed soldering tool or nut pick. I unsoldered the red/black wire pair and soldered them to the new switch. The small size of the mini-pushbutton allowed it to fit partway through the 1" by 2" switch/LED mounting piece. That allowed me to remount the front panel to the chassis (minus the round power-on/off cap with the power logo on it -- which was broken in my case anyway), leaving the pushbutton available for use.
on Jun 17, 2012 | HP Computers & Internet
What is the name of the missing transistor at the space Q601?
I was looking for the same information, I found that the (Phillips 22PFL4507/F8, and 22PFL4507/F7) use the same power supply as the emerson, only difference, emerson I could not find a schematic, phillips I scored one..
Q601 is part number TK5A50D
22PFL4507 F7 Brand Model Chassis
Apr 29, 2014 | Emerson Televison & Video
Dome light relay
Door courtesy switch malfunction.Dome switch mallfunction.Front body chassis windscreen pillar (columns)masks reveal wiring.Cheers,hope u figure it out,let the masses know.
Oct 26, 2013 | Nissan Maxima Cars & Trucks
Hello FixYa, I am in need of a little help or pointers. I'm trying to connect a period correct radio into a 1972 246GT Dino and have a question about electrical connections. 1. I know where th
1. Not sure what color on your ferrari is the wire to connect radio + to but with a voltage tester it shouldn't be too hard to find one that has power when ignition is switched on 2. ground to any metal part of dash that is bolted or welded to chassis should work well. 3. power antenna should be connected to the wire from the radio that has power coming out when ignition is switched on and radio lights up. Again use volt tester to check which wire has power when radio on!
Dec 23, 2012 | Ignition System for Ferrari Dino 246 GT -...
How can i disable chassis intrusion on p5kpl-am se board? the board don't have any intrusion switch...
For the chassis intrusion circuit to work, the chassis power supply must be connected to AC power. By default, on the motherboard the pin labeled chassis "signal" and "ground" are shorted with a jumper cap. You need to remove the jumper caps if you intend to use the chassis intrusion
hope this helps
Dec 07, 2010 | ASUS P5KPL-AM SE Motherboard
Although tradesman moterhomde plugged into electrical, engine's battery loses power, any suggestions as to why?
I am assuning you have an operation (read "working") isolation switch in your system. Such a switch (mechanical or electronic) will isolate your coach battery from your chassis batery. If you dont drive the vehicle often, it is possible for your chassis battery to go dead while the coach battery remains in tip top condition. (Coach is always on "charge". Im going to guess your chassis battery is not new.
Of course when you drive, you charge the chassis battery and in some installations, you also charge the coach battery. You dont want the coach battery to run the chassis - think about it and you will understand why. Other installations provide a switch that will allow you to start the vehicle with the coach battery if required.
If you dont go out often, consider a small trickle charger for your chassis battery. Since you keep your motor home plugged in, you have 110 V AC power available in the coach. Just plug your small trickle charger into the motor home and charge your chassis battery. Remember to disconnect the charger before you start the coach.
Safe travels. Let me know if this helps.
A
Sep 21, 2009 | Measuring Tools & Sensors
Front panel ceonnctor
Intel® Desktop Boards meet the ATX motherboard design guide specification using a 9-pin front chassis header. Special attention is required when attaching the front panel connector from the chassis to the Intel desktop board.
Front Panel Header
Description Pins Hard Drive LED 1 - 3 Power LED 2 - 4 Reset 5 - 7 Power ON (Power Switch) 6 - 8Lou
Aug 25, 2008 | Intel D845GVSR Motherboard
Emerson TC1351 chassis power switch doesn?t work but remote power does. I have opened the set and used contact cleaner on the chassis switch but no change. Any ideas?
If that contact cleaner did not work, get a new switch and replace it.
Before replacing it just short both contacts where the switch is soldered, the TV should turn ON and OFF.
Good Luck.
Feb 17, 2008 | Emerson TC1351 13" TV
Televison & Video Logo
107 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
