Copies come out blank. - Office Equipment & Supplies
What is the make and model of your copier?
Posted on Feb 02, 2010
BLANK COPIES
Check 1st the charging corona wires for cutoff or spark on both ends.. replace it.
Oct 09, 2014 | Konica Minolta Kip 3000 Series Printer
Prints blank page even in demo page! all toner are full! any solutions guys? thanks...
Hi Lee,
Try the document I linked below. It tackles blank copies which is close to what you are experiencing. Scans or Copies Are Blank
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For HP Printer Support
Feb 06, 2014 | HP Laserjet Cp2025n Printer
The printer runs properly but will not print; A blank page cycles
It is not the toner. There are 2 things you can try yourself, anything else requires service. First try opeing and closing the right hand side door. Try this several times if necessary. There are contacts in this door that sometimes don't make contact and opening/closing the door will sometimes resolve blank copies. The other thing you can try is remove the toner then pull out and reseat the drum unit. Here again there are contacts that need to be made that can cause blank copies.
Good Luck and Thank You for using Fixya.
Apr 09, 2010 | Sharp AL 1631 Copier
Blank copies on brand new Toshiba e-Studio 120
Did you pull the plastic tape off of the toner cart?
Feb 18, 2010 | Toshiba e-Studio120 Copier
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Top load copies are blank
I tried changing the the size to a reduction. It took the sheet from the top and copied it at a reduced size with no problem. Then I switched back to normal size and it worked just fine. I would have never thought to try a different size without your suggestion. Thanks for the help
Randy
Jul 17, 2009 | Sharp Office Equipment & Supplies
Blank copies
see the cartridge do is good installed.
Remove the cartridge and putt it again.
If the problem do not go away please try with other cartridge.
Or if the printer is ink-jet printer and you have not used it for some time than the ink can be stuck
Jul 16, 2009 | Office Equipment & Supplies
Blank copies
are you sure it clicked into place? did you move a lever to take out the cartridge?
Jun 11, 2008 | Canon imageCLASS D860 All-In-One Laser...
No Copies
It could possibly be your main charge assembly. If there is no charge on your drum, it can lead to blank copies.
May 20, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Ricoh 6513-Blank copies
hi im jules_09,check the transfer unit then the drum charge unit blank copies indicate that there is no high voltage that attach the toner to the drum.
Nov 15, 2007 | Ricoh 6513 Copier
13 people viewed this question
jasbo
jasbo
