Question about Ovens
Whirlpool oven model RDE6030A the bottom element
Whirlpool oven model RDE6030A the bottom element is not working, infact it has broken in pieces. I would like information on replaceing this element if possible.
  • 619 Answers
Unplug stove and remove screws holding element to oven cavity. Remove and take to nearest appliance shop and they will match up for you. Not an expensive repair. Hope this helps.
Posted on Feb 02, 2010
When baking in whirlpool accubake electric stove model GR475LXMS only the broiler works not bottom element what could be wrong?
The element could be open or the thermostat for the oven could be stopping power from reaching the element
Oct 17, 2016 | Whirlpool Ovens
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool gold double oven model #gbd307pdb. upper oven lower heating element burned out. replace lower element. it does not get hot. upper element heats up. control board works. is this the thermos
You will have to see if there is power to the element. It is possible that the relay contacts burned when the element burned out. There is a fusable link but this would shut down both the top and bottom elements. If the relay is burned out the control board will need replacing or rebuilding.
Oct 28, 2014 | Ovens
Whirlpool oven WGP30801
Your model suggest a gas unit on gas units only bottom burner operates in bake on electric bottom elements heats broil cycles.
Feb 12, 2014 | Ovens
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Whirlpool Gold Electric convection oven does not heat up.
Check for a broken wire or even broken element on top and bottom of unit. To do this, the unit must be unplugged or otherwise removed from power completely, then remove the screws that hold each heating element in place and gently pull out and inspect the wire connections. You should have just enough slack to check them. There should also be just enough slack to strip the wire clean to make the new connection to the heating element.
If the repair has been done before, you may need to fish a new lingth of high temp wire into the location.
Jul 13, 2012 | Whirlpool Ovens
My oven takes too long to heat up. I think the bottom element is not working properly. Is there some way I can test it?
If the bottom element is accesable take a piece of thermal printing paper and lay it on the element, then switch on. If the element is working the paper will turn black where it is in contact with the element, if you are daring, test it as you would your cloths iron, with a wetted finger, if it sizzles, the element is hot. You are not touching the electrical wiring, only the cover, but be fast with the touch test, you do not want to burn yourself. If the element is not directly accesable, try the thhermal paper test over the cover of the element, leaving the door open, it should turn black where the slots are in the cover, and then blacken all over. (Check to see if the oven switch does not have a position where the bottom element is isolated).
Jan 10, 2011 | Whirlpool RBS275PD Electric Single Oven
Broken Bottom Element
Remove the element and take it with you to a appliance parts supply.
They will match it with the correct replacement.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
91 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
