Question about Kenmore Washing Machines
When the washing machine is off, water continues to slowly drip inside the washing machine. If we turn off the water where the hoses are connected to the wall, the dripping stops. Any idea what might be causing this?
  • 807 Answers
Could be a build up of limescale inside the water inlet valves stopping them from sealing properly when they close. Unless you feel confident enough to take it apart you should get an engineer in to look at it.
Posted on Feb 02, 2010
8.5L LG turbo drum washing machine. The cold water is coming out of the tap but dripping slowly through he machine? What do you suggest to do? But the hot water is working with no problems at all?
ck to see if valve that feeds cold water is open at least as far as hot water is ? also try closing water valves and removing hoses from machine , look into end (both) there are small screens inside there are they part blocked off by something ?
Jan 29, 2016 | LG Washing Machines
Why does the rinse cold water drip in so slowly?
check filter (screen) in water valve intake and hoses to do so you need to take the water hoses off
Oct 07, 2014 | Whirlpool Washing Machines
Water continues to drip into the tub even after all cycles have completed. my tub is filling up with water, I have turned off the water to the machine but it continues.
The water inlet valve needs to be replaced. It's not shutting off the water completely. It's located where the water hoses connect to the washer.
Oct 09, 2010 | Maytag Washing Machines
Slow drip of water inside the drum. Don't see no moisture but I can hear it dripping. No Moisture on the floor. Any ideas where it could be dripping from?
Turn the water faucets off and listen for the drip to stop.
If the dripping noise stops,replace the water inlet valve on the washer were the hoses connect.
Enter your model number in the site referenced here for parts.
www.appliancepartspros.com
Jan 24, 2010 | Maytag Washing Machines
Water continues to drip into the washer when it is finished with cycle and turned off
Water valve is located at the rear of the machine with the water hoses attached to it. Disconnect power. Remove hoses and unscrew the small angled bracket attached to the valve. Replace the valve and your problem will be solved. Part Number is 2200270. This the only possible cause for the symptom you describe.
Oct 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water drips (tiny drop) slowly from top of washing machine when the machine is off (not from where the water comes from when it is on...but from that same direction). What could be the problem? (Maytag...
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the inlet valve. Make sure they are clear of rust or debris. Next, check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Sure hope this helps and best wishes.
Sep 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water drip
There is a water fill valve that allows water in, mixes cold and hot water or shuts it off. Its location is where the hot and cold water hoses connect to the washer.
Get the model number off the machine and go to the web site below and you can see the valve and also the cost of the valve should you choose to fix it.
http://www.appliancepartspros.com/partsearch/
Good luck, let me know.
Regards,
Jul 31, 2009 | Washing Machines
Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Mar 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Washing Machines Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
