Question about Dell Studio 1535 Notebook
I recently tried to fix the speakers cable, because the left speaker wasnt working, in the process i think i hit my screwdriver off the motherboard. I had to fix the laptop while it was on to check the speakers just worked. it froze, turned off. Wont turn on again. any help? :( So annoyed and sad now.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 168 Answers
Hello Dear,
You need not to be so depressed. By such ****, it may happen that the laptop's battery is somewhat misplaced. You just take the battery out for some time and then put it back and ON the system by pressing the power button.
Thanks
Posted on Feb 02, 2010
Sound?? Inspiron 1100 problem
Please varify that the sound is not set to mute.....check the volume control dial on the side of the notbook where the sound jacks are...verify its not set to minimum....
do you just rely on your pc speakers have you tried with an external speaker.....
keep me posted....and please don't forget to vote if this works for you
Cheers!
Nov 13, 2008 | Dell Inspiron 1100 Notebook
Right rear speaker not working
Start by connecting it to one of the other outputs off the deck, say the left rear. If it still doesn't work, remove the speaker and connect it directly to the head unit. If it works, then it's the speaker wire, if it doesn't, it's the speaker.
If there are amplifiers installed, switch RCA cables left for right etc. and see if the problem moves with the cable switch, try the same with the speaker connections at the amp. This will narrow down whether it's the amp or the RCA cable etc.
Car audio problems can be handled by a process of elimination! Eliminate what it's not and you're pointed directly to what it is.
Oct 06, 2008 | Pioneer DEH-P7700MP CD Player
Only right speaker working
disconnect all the cables and fix it again,then check the speaker sounds bychecking the sound settings in control pannel.
Aug 03, 2008 | HP JBL Platinum Computer Speakers
Logitech x-230 - left speaker not working when used with 360
my speakers plug into my comp. by that little cord with the green end piece. and i have to figit around with it just to get one speaker to work, can i fix it or do i have to buy the whole set again?
Mar 10, 2008 | Logitech X-230 Computer Speakers
Center Speaker sound just not right
If the optical cable was bad, the sound would be distorted period. The optical cable (whether coax or fiber) just simply carries the coded audio to the receiver which in turn decodes it. I have never heard of a signal just screwing up the center channel, and I've been at this better than 30 years. Not to say it's impossible, but very unlikely.
Did you try swapping speakers? Move the left one to the center and the center to the left. Does the center remain "distorted"? Does the left become "distorted"? If the center remains distorted, the receiver's center channel has something wrong with it. If the left is distorted, the speaker has a problem.
For the future. it is un-neceaasy to purchase expensive cables. In fact it could make things worse. The claim to fame of most expensive cable manufacturers is the gold plating on the connectors. Unless the bioth sides have gold plating (receiver, cable box) this actually creates a capacitive reactance between the different metal types. FYI-capacitive and inductive capacitances are the basis for designeing cross-overs, filters, etc. So basically, an undesired filtering effect is created. This applies to speaker cables, audio, video, etc....
Jeff
Feb 15, 2008 | Harman Kardon AVR 635 Receiver
One speaker has stopped working
It could be the cable connecting to the speaker, or the speaker itself. Try taking the cable that's connected to the left speaker and connecting it to the right speaker. If it works, the cable connected to your right speaker is defective, if it doesn't work - your speaker is.
Jan 10, 2008 | Toshiba 36A43 36" TV
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
MS-900 (AOpen speakers)
please install motherboard cd in you pc then set the volume control option to windows default thats all..your speakers will get ready to work properly...
Dec 30, 2007 | AOpen MS-900 Computer Speakers
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Mar 15, 2007 | Sony STR-DE545 Receiver
Right Speaker Hit the Floor
Im sorry to say so, but the fact that speaker can still monitor volume has nothing to do with its disability to produce sound. Im not a speaker wiz, but I can think of two possible reasons for what happened: 1. something has broken inside the speaker. in this case you will have to get it fixed\replaced. 2. some disconnection accured from the hit, a wire got teared or loosed. in this case, you might get lucky. open the speaker, and search for any torn wires. if you are handy you may be able to weld, replace, etc.
Mar 24, 2006 | Altec Lansing VS2121 Computer Speakers
Dell Studio 1535 Notebook Logo
43 people viewed this question
Alun Cox
