Question about Garden
My house, double wall construction, has outside sidings of cedar shingles, 16 inches long and 3/8 inch thick. The house is 17 years old and has been twice re-stained with with latex stain. Many shingles are loose and some are warped, the house is located in Honolulu and occasional exposed to strong winds and rain and to lots of sunshine. Besides replacing individual shingles, is there a simpler way to make the shingles tight again. Can they be simply nailed from the outside surface? What nails should be used to prevent leakage? Should the nail heads be sealed? The second question is: Would an acrylic paint provide a better and longer lasting protection? Can an acrylic paint be applied over the stained shingles without having to do extensive surface preparation?
  • aschenbrk001 Feb 02, 2010
    The answer I received from smartr1OU makes sense but I would like to get a second opinion.
  • 770 Answers
The conventional way to attach the siding is with a galvanized nail, however, with the nature of that particular wood, splitting, warpage etc, combined with the elements in your area...you will be quite prone to "nail pops"...a nail being pulled slightly out and having to be put back down. This makes them difficult to seal. I like to use a galvanized or stainless wood or decking screw, that will never pop out, and torqued properly, will not require sealing! As for your stain, because of where you are at, I would select a good grade of oil base sealer..with the stain tint of your choice. This can be rolled, brushed or sprayed. Your surface should not have to be prepped, other than the maintennance of securing the loose ones. It is recommended when re-attaching, to drill a pilot hole to put the screw in to reduce the chance of splitting the shingle. Good Luck, I hope you find this to be very helpful!
Posted on Feb 02, 2010
  • 1,305 Answers
Shingles and salty air, sunshine can really beat up shingles!
If this were my house, this is what I'd do:
First for the loose shingles:
Try securing with galvanized screws. BUT IT WILL BE VERY IMPORTANT TO PREDRILL AND COUNTERSINK YOUR SCREWS.
These shingles will split like crazy and your only hope will be to predrill and countersink. You can even put a bead of exterior grade elastomeric type caulking under the bottom edge of the shingles to hold them.
Secondly for the paint: Test a small section first and check the results before doing the whole thing.
Good luck on this.
k
Tip
How to build a Dog Cabin Dog House
You can use your creativity with this but I have discovered that landscaping timbers make a great log cabin for dogs. It is cooler in the Summer and warm in the Winter. I set mine on concrete blocks but a solid foundation would be nice as well. I framed the floor with 3/4 inch plywood and treated 2x4's and tied every log with 6 inch lag bolts.Each log had 4 lag bolts which run into the wood below. In between the logs I ran a line of liquid nails to seal the cracks as well as give it more strength and weather proof it. I filled it with cedar chips for both comfort for my doggies as well as insect repellent. I chose a standard house style roof frame and metal roofing but you could do shingles just as easy. I am happy to now have an all weather dog house on a permanent location at half the cost of having a not so well built pre-made dog house. I hope this inspires someone else as well. My dog cabin shown here is 8'4" square.
on Aug 06, 2015 | Miscellaneous
How to vent exhaust outside
bea12bfe-3a65-4764-8544-5bc63391c2dc.jpg9dbdeaa6-0b81-4926-ab21-2206dc8f6420.jpg6bfcce66-f35e-4950-b5c4-5ba9eff2c34c.jpgI usually choose an outside wall if possible to vent outside. You can buy a rear vent that is superior to a dryer vent. When this isn't possible you need a rectangular duct going up through your cabinet and up through your ceiling. hopefully you have an attic or you have to switch to a 5 inch tube going sideways (above your cabinets (if there is space) to the outside wall. If it goes into an attic you have to cut through the shingles to a vent made for bathroom and or hood vents. The motor and blower assembly inside your microwave is designed to turn to be front facing, rear facing or vertical facing. Just unscrew or break out the side that you need to vent through.
Oct 21, 2013 | GE Spacemaker JVM1540 Microwave Oven
What is the recommended drywall thickness for studs that are 24" apart?
5/8 of an inch is recommended. You may be able to get away with 1/2 inch if you don't really care, but i would check with the building inspector first
Jan 16, 2013 | Drywall
Replace shower door
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 20, 2012 | Home
The previous owner installed a concrete block chimney for a woodstove in the basement. He did not tie in the chimney at the top and there is some movement. I want to secure to the house now and next summer...
If you are talking about side to side or horizontal movement. A easy temporary fix would be if you can get to it in attic is to use 1 1/2 inch angle iron. Cut four pieces three inches longer than outside dimensions of chimney. Take peices for front and back so that bottom side of angle sets flat against chimney.Lay two other pieces on top of of first two so that top edge of angle lays flat against chimney. Mark and drill 5/16 inch holes so that outside corners can be bolted together. I would use 1/4 x 1 1/2 inch hex bolts and nuts to fasten angle iron together. I should have said that the thickness of the angle iron could be 1/8 or 1/4 inch. Position support bracket so that you can use pieces of angle iron or strap iron from bracket to top or side of rafters or trusses. Drill holes in bracket end so you can use corner bolts and measure and cut to length as needed to reach nearest rafter. Drill 2 3/16 holes on end to be secured to rafter and nail with 16D nails. Secure all four sides and you should be good for now. Hope this helps. Thanks
Nov 14, 2010 | Garden
Tire size for 2004 impala
2004 CHEVROLET IMPALA BASE/LS 16-INCH
225/60-16
2004 CHEVROLET IMPALA BASE/LS 16-INCH- (TPMS)
225/60-16
2004 CHEVROLET IMPALA SS 17-INCH
235/55-17
2004 CHEVROLET IMPALA SS 17-INCH- (TPMS)
235/55-17
Sep 23, 2010 | 2004 Chevrolet Impala
Where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
Monitor
Monitor sizes are measured on the diagonal from corner to corner.
A 17" LCD may have a screen width of 12 inches measured from side to side.
If you are measuring a old style CRT monitor (Cathode Ray tube) the visible screen area will be about an inch less as there is about 1/2 inch of plastic frame holding the CRT in the chassis. The manufacturer can advertise the actual size of the screen regardless of how much is actually visible to display information.
If you are talking about software not utilizing all the available screen area to display the image, that is an issue with the people writing the software code not keeping up with the changes in hardware.
In the past year or two, most displays have switched to the 16:9 and 16:10 wide aspect ratios while most web content is still written for the 4:3 old style aspect ratio. Eventually, software developers will catch up with cusrrent hardware.
Jul 25, 2008 | Gateway FPD2275W LCD Monitor
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
