Question about Muratec F-520D Fax
Where can I get parts for Muratec F-520 fax. I need Pickup roller and separator pad.
    Genius:
  • 1,218 Answers
Pick-up roller comes as an assbly and there are 2 pads to replace.
Roller assbly is # DA7A003040
1st pad is #DA7A004050
2nd Pad is #DA7A005050
Contact a local copier dealer who also does Muratec, they should be able to sell you these parts.
Posted on May 28, 2010
MORE THAN ONE SHEET GOES THROUGH AT A TIME
clean all the rollers or if the fax has a separation pad replace it.. yes it does have a separation pad the part number is Samsung JC73-00140A you can purchase this item at Precision Roller for $10.00
Mar 06, 2014 | Samsung SF-560 Plain Paper Laser Fax
Hp laserjet 4250 feeds multiple pages through the manual feed tray
It sounds like the paper pickup roller and separation pad for tray 1 is worn and will need to be replaced. These two parts pickup the paper and weed the pages into the printer. When they get worn down they can grab more than one page at a time. The parts are user replaceable, no need to pay a big repair bill for something like this. The parts come in a kit with rollers and pads for tray 1 and tray 2 along with the instructions and it is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=302
Here is a picture of the roller and separation pad from the service manual.
I hope this helps you out.
Apr 11, 2013 | HP LaserJet 4250dtn Printer
My hp laserjet 1320 takes in more than one paper while printing, which get stuck.
Cleaning the pickup roller will only temporarily delay problem. The pickup roller and separation pad needs to be replaced to correct the multiple paper pickup problem. The roller and separation pad is easy to replace. These parts come in a kit caller RK-1320 the parts kit is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=71
Mar 28, 2013 | HP LaserJet 1320 Printer
Laserjet 4100 taking in extra paper
Picking up more than one sheet of paper indicates the pickup rollers and separation pad is worn and they will need to be replaced. These parts work together to pickup and separate the paper from the paper tray and when they get slick the rollers allow more than one sheet to enter the printer which causes a paper jam and misfeed errors. The rollers and separation pad come in a kit and is user installable, no need to pay big money for a repair shop to do it for you. The kit RK-4100 is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=259
Mar 28, 2013 | HP LaserJet 4100n Printer
Automatic document feeder(ADM) for Muratec F-112 fax-printer will not grab paper for processing. Wheel spins but paper does not advance unless forced into ADM
There is a small "re-feed" pad under the PF Roller which might need replacing OR the PF roller itself may need replacing. The machine when new should have come with a spare "re-feed" pad.
Nov 16, 2010 | Office Equipment & Supplies
Canon L75 draws all the paper at once
Try cleaning the pickup and separation rollers and /or pad inside the document feeder. If this doesnot help they need to be replaced contact your local canon dealer for help with parts.
Nov 28, 2009 | Canon FaxPhone L75 Plain Paper Laser
Got a new part. don't know how to install it
I assume you either have recieved the separation pad or the paperpick roller. Here are instructions on how to replace both.
  1. Use the power switch to turn the product off and then unplug the power cord. Figure 1: Unplugging the power cord c00062340.gif
  2. Open the print-cartridge door, and remove the print cartridge. CAUTION: To prevent damage, do not expose the print cartridge to light. Cover the print cartridge or place it in a black plastic bag, if necessary. Also, do not touch the black-sponge transfer roller inside the product. Touching the transfer roller can damage the product.
  3. Locate the pickup roller. Figure 2: Removing the print cartridge, and locating roller c00062341.gif
  4. Gently release the small, white tabs on each side of the pickup roller by pushing them away from the roller, and then rotate the pickup roller toward the front. CAUTION: Use gentle pressure to release the small white tabs to avoid breaking them. Figure 3: Releasing the tabs c00062342.gif
  5. Gently pull the pickup roller up and out. Figure 4: Removing pickup roller c00062343.gif
  6. Perform one of the two following options:
    • Cleaning the pickup roller:
      1. Dampen a lint-free cloth with isopropyl alcohol, and scrub the roller.
      2. Using a dry lint free cloth, wipe the pickup roller to remove loosened dirt. Figure 5: Wiping the pickup roller c00062344.gif
    • Removing the new pickup roller from its packaging.
  7. Position the cleaned or replacement pickup roller in the slots on the pickup roller frame. NOTE: Circular and rectangular pegs on each side prevent incorrectly positioning the pickup roller. Figure 6: Positioning pickup roller c00062345.gif
  8. Rotate the top of the pickup roller into position until the white tabs on each side of the roller snap into place. NOTE: Touching the transfer roller can damage the product. Figure 7: Reinstalling the pickup roller c00062346.gif
  9. Reinstall the print cartridge and close the print-cartridge door.
  10. Plug the product in, and then use the power switch to turn on the product. Figure 8: Plugging the power cord in c00062347.gif
  11. Use the power switch to turn the product off and unplug the power cord. Figure 1: Turning off power and remove power cord c00062407.gif
  12. At the back of the product, unscrew the two screws that fasten the separation pad and frame to the product. Figure 2: Unscrewing the separation pad c00062408.gif
  13. Remove the separation pad and frame. Figure 3: Removing the separation pad c00062409.gif
  14. Perform one of the following two options:
    • To clean the separation pad: Dampen a lint-free cloth with isopropyl alcohol, and scrub the separation pad.
    • To replace the separation pad: Remove the new separation pad from its packaging
  15. Insert either the cleaned or replacement separation pad and frame and fasten it to the product with the two screws. Figure 4: Fastening the separation pad c00062410.gif
  16. Plug the product in, and then use the power switch to turn on the product. Figure 5: Turning the product on c00062411.gif
Nov 17, 2008 | HP LaserJet 3015 All-In-One Printer
Paper jams at pickup from tray
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
MURATEC F-520 ERROR CODE 04
This code relates to a Drum Cartridge Problem.
Check the cartridge is installed correctly or at least try another drum cartridge.
Oct 03, 2007 | Muratec F360 Plain Paper Laser Fax
The printer takes all the papers in but prints on one how can i make it take one pagg at a time
you will need som of these rollers: Paper feed Roller Ass'y part No: RM1-0037-020 Paper Pick-Up Roller ass'y Part No: RM1-0036-020 Google the part number and you should be able to find a local dealer of them
Sep 14, 2006 | Canon LBP 800 Laser Printer
453 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
