Question about Frigidaire GLEQ2152ES Electric Dryer
Everything works fine. Loud, squeaking noise in the back of the drum?
  • 572 Answers
U need to lubricate your bearing in the back.
Posted on Feb 05, 2010
Constant loud squeaking
Squeaking is normally caused by a bad bearing or a slipping drum belt.
Feb 28, 2015 | Dryers
Bosch Maxx wfl 1300 washing machine - drum making loud squeaking noise.
sounds like bearing have failed or the stainless steel drum has detached from its carrier open the door and try to move the drum up and down there should be no movement at all if there is machine will need to stripped down
Mar 03, 2014 | Washing Machines
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Loud squeaking noise
dont spray that on the belt lol that stuff is flamable i think lol you most likely have bad phelt glides  they are pads that sit between the drum and the drum support and when that wears out it squicks or maybe you have a bad idler pulley which is what holds the belt maybe its rusty or something but most likelt its the pads
Jun 09, 2009 | Maytag MDE6000 Dryer
Squeaking dryer drum when operating
sounds like you need to adjust the motor that turns the drum to tighten the drive belt..... you do this from the back or bottom...
May 24, 2009 | Fisher and Paykel DG05 Gas Dryer
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Loud Squeaking Noise kenmore gas dryer 80 series
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Dec 07, 2007 | Kenmore 63942 Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
120 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
