Question about Funai PY90DG DVD Recorder
How to finalize a DVD record in PY90DG to make it compatible in other players
After recording and pressing the stop button, how to proceed with "finalising" the DVD recording to make is compatible for other players.
my email ID: basava_swamy@yahoo.com
Http://www.fatwallet.com/t/18/698308
the manual
Posted on Mar 09, 2008
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
Is there a way to record something on a dvd from the tv?
Which model do you have? Some of the GoVideo DVD/VCR units are only DVD players so you can only record to the VHS tape. If you have a DVD writer version, you may find it tedious but doable. First load the blank DVD and set the Disc Record mode (you will see an on-screen prompt) for VR (this lets you do more editing of the video) or Video (this choice is compatible with more players). Then set the REC Mode by pressing that button repeatedly (SP (2 hours per disc), LP or XP(1 hour per disc). For one-touch recording (recording the current program that you are receiving on the device), select your Channel and Audio track then press REC. If you press REC several times, you will set when the recording stops. Otherwise it will not end until you press STOP.
For timed recording, press Timer Record. Then go through all the items to set the DVD recording information. Record mode, Channel, start and stop times. The left and right arrows let you change menu sections and the up down scroll through the settings. Press Enter to save the programmed recording. Then press Return. Make sure blank media (or with enough room for the programmed item) is in the machine. On some units, you will need to turn off the machine for the Timed Recording to work.
For recording from external sources, press Input instead of Channel.
For any recording, leave a bit of extra space on the disc to Finalize the DVD if you will want to play the disc on other players.
I hope this helps.
Aug 15, 2010 | GoVideo Go Video DVD/VCR Combo
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Finalizing
Use a name-brand DVD, such as HP, Verbatim, etc. and make sure it is a DVD+R or DVD-RW/-R disk only.
It is most likely that the DVD you are using is not compatible.
The disk is still usable, but you can only read it on that player.
Aug 17, 2009 | Funai PY90DG DVD Recorder
Playing recorded DVDs on PC or other DVD player
Hi
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Thanks
T.Boopathy
Aug 23, 2008 | Philips DVDR3455H/37B
Dvd finalization
I turned off the Colby recorder then turned it back on and inserted the DVD and chose the edit button on the remote controller. The correct menu with the close and finalize choice became available.
May 26, 2008 | Coby DVDR1280 DVD Recorder/HDD Recorder
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can i record from tv to dvd
yes
make sure the cables are connected correctly, the manual will show that.
If the mwr20v6 has a tuner you must have the channel on the dvd set to the program, if it has no tuner, you must have your tv set to the correct channel.
Feb 13, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Funai PY90DG DVD Recorder Logo
373 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
