The red color does'not work, the screen appear green only
    President:
  • 2,992 Answers
Unfortunately, it's not possible to give you any advice about where to start trying to repair this problem on your own. Missing colors on a TV can be caused by many things: simple bad solder connections, component failures, or a bad picture tube. Without the necessary test equipment and service information, it's nearly impossible to fix many troubles.
The only suggestion I can make is to take this set to a service shop (or call for home service if it's too large to carry) and get a repair estimate if you really want to keep the TV. Or use this as an excuse to replace the set. Especially if the tube is bad, repairs may be uneconomical.
I wish I could offer more help. Good luck and thanks for using Fixya~
Posted on Feb 02, 2010
Testimonial: "Tk a lot, very fast"
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Color is messed up...very green looking screen, appears red colors appear green
Do you have extra hardware connected to the TV? If so, it could be a problem with the cable/connections.
Mar 07, 2011 | Proview Hx263 26 in. HD-Ready LCD...
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Screen turns green and red lines appear across
my HD LCD used to turn grey on my 360 so i just turned it off then back on for the results but of coures it could be the LCD is dying
Dec 28, 2009 | Microsoft Xbox 360 Console
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEAR ON THE SCREEN...
Remove battery , let sit for 2 miniutes . Re install battery , in proper position , hold on button for a few seconds and this should work ...
Jun 11, 2017 | HTC TYTN GSM Phone
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Dec 05, 2007 | AOpen 19" LCD
One of the primary color is absent
Hey Kuld.. Just asking... since both, your TV and your monitor have the same color issue...??.... have you been to the optometrist lately... (My Dad had this color issue with his eyes!).. he was red color blind..
Good luck,
Jun 20, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
