Question about Panasonic Televison & Video
I have a Panasonic HDTV and suddenly the colours went double!
I have a Panasonic HDTV and suddenly the colours became messed up. There were doubles of everything and those doubles were red. I tried converging but the red won't line up with the blue crosses. How will I fix my colours?
    Problem Solver:
  • 5 Answers
Hi, if you know little fixing tip's? here's my tip's sound's like converging ic's,gone bad. on the left board there's two a touched to a big heat sink.but before you start'.there's three wire connected to the board written. red .blue.and green.check for burn film resistor's on line red. replaced it with the same.good luck.
Posted on Feb 20, 2010
I just replaced the lamp on my panasonic HDTV. Now the green light flashes, then it turns off and the temp light flashes. What could it be? Did I replace the lamp correctly?
you,if did not have this exact issue before, double check everything you did when replacing the lamp including where it plugs in that it went in correctly.
Dec 22, 2012 | Panasonic PT-56DLX25 56" HDTV
Well i think i dropped my phone and suddenly there was a small crack, and the digital colours was messed up, 2 days later the crack became huge and the colours are still messed up, anyway to fix? i went to...
You can ask the phone shop to send it of for repair. It may cost around ?50 to get fixed. R u can go to a shop that unlocks phone and They maybe able to fix it there. so it wouldn't have to get it send off For repair.
Jan 16, 2011 | Cell Phones
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic HDTV from 2001. 51
I had the same problem and fixed it myself with a kit from www.TvRepairKits.com. Works great now.
Jan 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic hdtv 1080i all of the sudden has double
Go INTO the customer menu and select CONVERGENCE--what you are looking for is will blue or red not move in some direction?
If you find in your case blue OR red is wacked and will not adjust let me know--I can post here start to finish instructions for this repair on this set.....
You only need to be able to know how to solder and get at the chips--you can buy a pair of the chips on Ebay for less than 14 dollars plus shipping.
If you cannot do it yourself--let me know and I will give you options.
I am here to help people--if this information helps you rate this solution--I do this here for free.
SD TECH
Nov 03, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Picture is suddenly double , colour of also odd pink and greenish , nothing in manual describes problem
Ur convergence it dead,need buy a convergence kit,use what in that kit.U know how to solder right?Tries these websites.Tv Repair World.com or Ebay.com.
Oct 03, 2009 | Akai PT5598HD 55" Rear Projection...
Double Display on screen
The convergence Ics need replacement along with the 2.2 ohm 2 watt resistors. There is a repair kit available for your model which contains both the ICs and all six of the resistors and contains step by step instructions with pictures. Heres the link to the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Mar 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
I have a panasonic HDTV 1080i. seeing double images
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Feb 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem
Hi, you`ve lost the convergence IC`, requires a good knowledge of soldering and. posssibly an alignment after replacement, good luck, video-tek
Feb 14, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
