Question about Bosch WFK 2401
BOSCH WFK 2401 washer. It's been unused for 2 yrs. How much is a new motor and how do I remove the black plastic drainage panel (bottom/front) to reach the hoses behind which need cleaning. I've cleaned the exit hose and a complicated plastic part (inside/top/left). Odd set up for the power supply - the washer plugs into a box on the back of the dryer. Is this a voltage issue for these earlier models?
    Top Expert:
  • Bosch Master
  • 41,676 Answers
"How much is a new motor" Fixya does not sell replacement motors.
Posted on Jul 28, 2017
  • 1462 Answers
SOURCE: Bosch Washer WFK 2401
leaks could be from anywhere. remove the top and back cover, put on a cycle and try to trace where leak is. sorry if this is not very helpful. water in filter should not smell. this may be due to using liquid detergent which causes a smell like drains if used over a period. put on a boil wash and revert to using powder
Posted on Jun 14, 2007
jason0110
  • 66 Answers
SOURCE: Bosch WFK 2401 problem, please help
this could be a block in the pump or motor brushes would go for the pump
Posted on Jun 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Posted on Jan 03, 2009
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • 88 Answers
SOURCE: Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Posted on Apr 20, 2010
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Can I stack my bosch wfk 2401 on top of my bosch wtl 5400
I wouldn't. Not without a proper shelf for the washer.
Washing machines are heavy because there's a huge lump of concrete placed over the drum to dampen down any vibrations. A tumble dryer is hollow, has little structural strength.
Put the machine on top of the dryer, you're going to get a crushed dryer if not a crushed foot, leg or child. Please be very careful.
Nov 11, 2011 | Bosch WFK 2401
Apr 20, 2010 | Bosch WFK 2401
How to change the door seal for the Bosch WFK2401 washer
Most bosch front panels can be removed by removing soap disp. then 6 screwss top/ bottom .remove door interlock..The boot seal is held by a spring ring onto the outer drum...you may find video on this @ utube...hope this helps
Sep 29, 2009 | Bosch WFK 2401
Bosch WFK 2401On/Off Switch
You need a new switch should be able to buy on its own note wiring before doing.. it just pops out i think..good luck
Sep 08, 2009 | Bosch WFK 2401
Not Draining or Spinning
Check to see if there is a removable lower plastic cover at bottom front of washer, if there is remove it ,and on the lower right hand side, you should find the pump filter.
Unscrew anti-clockwise, remove and clean.
Please rate my solution.
Thanks.
May 30, 2009 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove drive belt.
Remove motor plug
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Changing bushes on bosch classixx1200
To change brushes in Bosch motor.
Remove rear panel of washer, undo 2 screws that secure motor at front end, remove motor plug, lever motor back with a screwdriver or similar, and remove motor retaining a hold on it,\ so as not to drop it .
Replace brushes fitted at rear end of notor.
Refit motor and belt.
Thanks.
Jan 08, 2009 | Bosch WFK 2401
Jun 12, 2007 | Bosch WFK 2401
Washing machine
There are 2 ways: 1. Tip machine on its back and remove the sump hose from the bottom of the tub, and root around inside. This option doesn't give you much play. 2. Remove the from of the machine and the heater element. 1. remove soap drawer and undo resessed screw 2. remove kick strip and remove screws behind it 3. remove door seal band and front of door seal 4. slide front panel down and towards you to remove. 5. remove heater element to gain access to inner drum. With the sump hose also off you should be able to remove the foreign object. http://www.ransomspares.co.uk/bosch-washing-machine-spares.html
Mar 01, 2007 | Bosch Classixx WFO 2866 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
