Question about Ovens
Igniter will heat up (glow), and oven may or may not light for 5 minutes (with igniter glowing). After heating, and stabilizing...once the oven starts to cool, igniter will glow again, and may or may not relight (to bring the temp back up).
  • Ovens Master
  • 8,220 Answers
The stove should not take over 3 minutes to light. Even if the ignitor is glowing it is impossible to really tell if it is ok or not. When the ignitor heats up it's resistance drops, this allows for the amp draw to get to 3.2 amps or better and that opens the bi-metal inside the oven valve. The oven circuit consists of a control to regulate temp, a safety valve, a ignitor, and a burner. Any open component and the oven will not fire off. If all the components have continuity and the ignitor is glowing, but no joy, I would replace the ignitor. Usually the ignitor gets dim when it is weak and it takes a long time to light off and you might even have to bump the stove and get it to come on. Replace that ignitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 02, 2010
Why wont my bottom oven heat up, it will ignite but wont heat,has the bulb anything to do with it,its blown HELP ZANUSSI ZCG660GXC LPG gas with electric ignition and clock.
The gas valve for the lower oven won't open after the igniter starts glowing. If there is no orange glow from the igniter, then it needs to be replaced.
Jun 19, 2015 | Zanussi Ovens
KENMORE GAS STOVE OVEN , how to check if power is coming to the ignitor
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Sep 07, 2014 | Kenmore 24 in. Gas Self-Clean Single Wall...
I have a 5 burner gas range and cooktop one burner on cooktop won't start
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 12, 2014 | Kenmore Elite Stainless Steel 40" Dual...
Oven starts and stops
Apr 02, 2014 | Kenmore Ovens
If oven igniter is not getting power what is the cause. Oven is plugged in. Broiler igniter works.
Feb 04, 2014 | Kenmore Ovens
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfodk0nzawndcvq0fnl3nvdg9ochryyxav
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=74007498
Sep 28, 2010 | Ovens
Oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Aug 17, 2009 | Ovens
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
Frigidaire Gas Oven
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Jul 10, 2008 | Frigidaire FGB24L2A Gas Single Oven
Ovens Logo
62 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
