Question about Xerox 5665 Copier
Xerox 5614 has a j8 code and will not reset. I have checked to make sure the exact cartridge was installed. The J-8 code will not go away.
Xerox copier 5614
Posted on Jun 23, 2010
Fix error code on phaser 5500
That error means wrong toner installed. Are you using OEM toner? If it's not the toner it's the Crum board that recognized the toner, part number 160K95831.
Sep 01, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox copier 5614 stopped and posted error message J8; I cleaned the copier, replaced the cartridge with a new one, and after closing it up again, the J8 message continued. I have shut the copier down,...
This error code normally is for incorrect cartridge or not seated properly.
Trying cleaning on the copier cavity area that hold the cartridge. Make sure the power is off first.The sensors might be blocked by dust and dirt. Then reinstall the cartridge and try again. Hope this helps.
Feb 17, 2011 | Xerox 5665 Copier
Keep getting dark copies from my Xerox 5614
This machine was bad on this problem. This machine needs a developer assy and developer. part# 48k56280 (dev assy) 502s64233 developer
Nov 26, 2009 | Office Equipment & Supplies
Xerox 5614 has a j8 code and will not reset after I replaced the toner
J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM
Sep 17, 2009 | Office Equipment & Supplies
How do you reset the j8 code
J7 Drum unit due for replacing J8 Wrong drum unit or power was turned on after J7 displayed
U have to insert the new dram unit or change fuze 0.018 A in drum unit
Sep 17, 2009 | Xerox Office Equipment & Supplies
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
J8 Error Code
There are a few different part numbers for those cartridges, the chip on them bills differently.
A J8 means although you have a 212 cartridge, it has a chip on it that does not match your machine setup.
A J8 indicates a mismatch in the cartridges and the machine. No you do not have the wrong physical cartridge, it just has a different chip on it.
Nov 08, 2008 | Xerox 212 Laser Printer
Xerox XD105F Have J2 Code, Replaced Drum and Code has not Gone away, How do I reset
On the front of the drum cartridge there is a green cover, Behind that cover is a set of gears , one with a flag like actuator on it.
Most likely the flag dropped in shipping and did not reset the drum replacement switch.
You can either try popping that cover off and resetting that foag to the up and right position or take the cartridge back for replacement.
Aug 06, 2008 | Xerox Office Equipment & Supplies
Xerox 5614
The book says problem with wall outlet.
are your hot and neutral wires swapped? Ground ok?
you can obtain a simple tester at home depot
let me know if further assistance is needed
never had one throw this code before.
Apr 25, 2008 | Office Equipment & Supplies
191 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
