How to un-Dish a t.v.
Roofers took down our Dish today. We have a pre-HD Sharp t.v. we're trying to "Un-Dish" to watch on antenna. Not having any luck. What have we missed?
  • 350 Answers
In the USA broadcasts are not analog any longer they are digital. So if you have an antenna hooked up to your TV you will need a digital converter hooked up to your input wire (from antenna) and then an output from the converter to the TV. Most satellite and cable companies use RG56 cable which will work fine with an antenna set up as well, so cabling should not be a problem.
Make sure you set your TV mode (input or source) to the proper input where you have hooked up the cable to the TV as well. It is unimportant which input you use, but the TV has to have it set to the same one.
If you are outside of the USA, the above should be the same because broadcast over the air and antennas set ups are universally the same in nature and design. I hope this helps and good luck!
Posted on Feb 02, 2010
My receiver does not send hd signel to tv
are you getting a picture or show? if so is the show your trying to watch benning brodcasted in hd
May 08, 2013 | DISH Network VIP211k HD
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
Nesesito codigo para que mi control funcione para television SHARP y como ingresarlo
Hola mi nombre es Mayra Diaz con DISH Network. Sera un placer ayudarle y proveerle la informaci?n que necesita para programar un control de DISH Network a su televisor Sharp. Hay ciertos c?digos que se pueden integrar al control que le permiten funcionar con la televisor, unos de los c?digos serian los siguientes: 628, 739, 741, 608, y el 654. El procesamiento a integrarlos es el siguiente: Presione el bot?n de T.V localizado en la parte de arriba del control hasta que se prendan los dem?s en rojo una vez esto suceda ingrese uno de los c?digos seguido por el signo de numero por ejemplo (#700). El bot?n de T.V deber? iluminarse 3 veces en rojo si el c?digo es compatible. Despu?s de esto puede intentar usar el control con su T.V. Espero esto le sirva de ayuda si tiene preguntas adicionales o necesita ayuda puede contactarme directa mente a mi correo electr?nico
Apr 19, 2011 | DISH Network IR Remote Control
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Apr 04, 2011 | DISH Network IR Remote Control
Saludos tengo un recibidor 311 y se me dano mi control 3.2 ir y compre uno 21.0 ir/uhf y no se como programarlo
Hola mi nombre es Kimberly Escobar con DISH Network, tengo entendido que su control 3.2 esta danado y por esa razon compro un control 21.0. Siento decirle wue este nuevo control solamente es disenado para funcionar con nuestros recividores VIP HD. Necesita un control 3.2 para que funcione su recibidor. Nos puede llamar directamente al 1800-333-DISH y podemos ver su cuenta, si usted tiene el plan de proteccion en su cuenta el control se puede reemplazar gratis. Gracias y esperamos oir de usted pronto.
Feb 22, 2011 | DISH Network IR Remote Control
Codigos tv panasonic
codigos para programar el dish a mi tv marca sharp
Feb 12, 2011 | DISH Network IR Remote Control
Nesesito programar mi control a una televicion sharp
Hola mi nombre es Mayra Diaz con DISH Network. Con mucho gusto le puedo ayudar a programar su control a su televisor Sharp. El primer paso seria verificar que tenga bater?as nuevas el control. Vamos a presionar el bot?n de TV asta q las cuatro luces est?n encendidas esta localizado a un lado de SAT es un bot?n blanco. Despu?s que las cuatro luces est?n encendidas presiona estos siguientes c?digos 628, 605, 607, 655, 658, 669, 670. despu?s de presionar el primer c?digo presiono el cigno de numero localizado abajo del 9. Cada uno de los c?digos se tiene que tratar uno ala vez. Finalmente presiona volumen para verificar que funcione, no olvid? presionar SAT para poder seguir cambiando de canales. Si tiene alguna otra pregunta por favor escribanos.
Sep 30, 2010 | DISH Network IR Remote Control
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
