Want to know if i need to replace the water pump of my frigidaire washer or since its only the propeller that needs repair do they sell just the propeller?
  • neepin2010 Feb 02, 2010
    much thanks!!!
  • Washing Mach... Master
  • 8,220 Answers
Unfortunately the pump does not have replaceable parts.
Posted on Feb 02, 2010
I have a Frigidaire dishwasher model number FGBD2431KF purchased around 2009. Water is not pumping out.
Sc. Check the drain valve, remove the pump and test it. If it is not the pump then probably a relay or switch. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dishwasher Diagnostic Repair Not draining Frigidaire Electrolux...
Dishwasher Not Draining Dishwasher Drain Pump Replacement Part 5304463777
Frigidaire Dishwasher Not Draining
http://www.partselect.com/Repair/Dishwasher/Not-Draining
May 08, 2016 | Frigidaire Washing Machines
Frigidaire front loading washer will leave clothes soaking wet after final spin
Hi Friend, thank you for your post!
It appears you are having trouble with your Frigidaire washer not draining properly. Often, this is because your washer cannot dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your appliance. Best regards - Z.
Apr 05, 2014 | Frigidaire Washer water pump motor ASKOLL...
GWL15 has burning smell
You need a new pump! These are easily changed as I did it in less than 20 min. my 1st time.Disconnect the power and I turned my water valves off as well. Tilt the washer back and place a support under the leg, Do Not lay the washer on it's back. Take a flashlight and you will see the pump to the front right side (has a propeller). Disconnect the wires and slowly turn the pump counter clockwise and it should come loose. reverse the procedure to install the new one. They can be ordered online or check some of your local repair places that sell parts. The average cost is $75 to $100.
Nov 06, 2012 | Fisher and Paykel GWL11 Top Load Washer
Hello there It looks like my water pump (Direct Drive Pump Part Number: 131208500) is leaking. So what should be done: - get new sealing part or replace the whole unit? Thanks
It is only sold as a unit. You will need to replace it as a unit. If you know someone who
does apartment maintenance, they may be able to get this item at a lower price for you
at a local appliance parts vendor. hope this helps.
Sep 24, 2011 | Frigidaire 131208500 Frigidaire Washer...
Frigidaie affinity washer not puping water. I pulled the pup outy, it seems to be freely spinning. The filter looks like a pipe with an end cap. Does that come out and does it act as a filter. I did find...
the screws and nails were your problem put it back together if it still doesnt pump the pump motor has overloaded from the propeller being obstructed and needs to be replaced.
Jan 11, 2011 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front loader nightmare!
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Apr 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Error 20 on washer its a frigidaire front loader M# atfb7000seo
E20 .... I ALSO HAVE AN E20 WHICH I BELIEVE HAS SOMETHING TO DO WITH THE FACT THAT THE WATER IS NOT DRAINING FROM THE UNIT. MY ISSUE IS THAT THE PROPELLER IN THE PUMP BROKE AND WILL NOT PULL THE WATER TO DRAIN THE MACHINE. LISTEN TO IT WHEN YOU TRY TO RESTART THE CYCLE AND IF YOU CAN HEAR A RATTLE NOISE FROM THE BOTTOM OF THE MACHINE YOUR PUMP MAY NEED TO BE REPLACED OR NO NOISE MAY INDICATE THE PUMP HAS BURNED OUT. ONE OTHER THINK YOU MAY WANT TO CHECK BEFORE YOU GET SET ON REPLACING THE PUMP IS TO CHECK YOUR COIN COLLECTOR. REMOVE THE FRONT BOTTOM PANEL AND YOU WILL SEE A RUBBER BAG LOOKING THING THAT IS ATTACHED TO YOUR PUMP AND TUBE WITH CLAMPS. YOU MAY HAVE LINT OR A SOCK STUCK IN THE CATCH WHICH MAY BE PREVENTING WATER FROM DRAINING. I MUST WARN YOU IF YOU CANNOT GET YOUR MACHINE TO DRAIN BE PREPARED FOR A MINI FLOOD. HOPE THIS HELPS.
Dec 22, 2008 | Frigidaire ATF6000ES Front Load Washer
WILL NOT SPIN OR PUMP WATER OUT
took pump out there was a wire (under wire from bra) stuck in the propeller removed it put pump back on works fine now
Nov 05, 2008 | Frigidaire ATF6000ES Front Load Washer
I'm havin a problem with my washer!
It could be your belt(s) or water pump which works together to turn the tub and flush out the water, If the belt(s) is fine,,check the water pump, remove it and look for any debris, cracks, external water around or on the pump and worn parts. If any of these things are found, the water pump should be replace..
Noria1
Jun 18, 2008 | Frigidaire Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
