Question about Refrigerators
Waterdrain is pluged - Refrigerators
  • Refrigerators Master
  • 8,220 Answers
Use a hair dryer to melt any ice and a shop vac to open the drain. Wear gloves to keep from getting cut.
Posted on Feb 02, 2010
What does it mean when you get E2 and F5 error.
Look in the filterbasket that there is no object blocking the waterpump in your Samsung. a waterdrain problem
Feb 04, 2017 | Washing Machines
Oil in coolant resevior
head gasket if coolent is creamy white or brownish then yes head gasket do comresstion test sounds like water jacket leaking check sump oil fof any signs of waterDRAIN ENGINE OIL TO CHECKor my be someone has topped up radiator with oil.
Feb 19, 2015 | Cars & Trucks
Cannot view cameras live
Make sure your monitor is pluged into the input that is labeled Main Monitor or the VGA . it cant be pluged into the spot monitors .
Its the one on the bottom left . you probebly have it pluged into the call monitor output.
Apr 16, 2014 | EverFocus Ecor264-9x1/2t Dvr Digital Video...
Is there suppose to be a ball in the tube under the drum in the washer where the waterdrains?
Welcome to FixYa.
To answer your question in a word, Yes.
This is what you should see inside the tub to pump bellows, it's a back flow valve.
( maybe even the "gunk" included...should be cleaned out if present...run the washer on a hot cycle with some citrus based crystals/white vinegar or a product called "affresh" as shown below or remove it and clean it out thoroughly by hand )
Let me know if you require any further assistance and I'll try to help in any manner I can. Good luck.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My ford windstar wets pluges after which the car will not start. you need to clean the pluges before it will ever start. when it is driven it makes some shoting noise. I ve changed the pluges, clean the...
If it is all plugs I would check the fuel pressure regulator, see if gas leaks out of it when you remove the vacuum hose. It is located on top of the engine, near the fuel rail.
Jan 07, 2011 | 2001 Ford Windstar
I have a 60 series top load washer and on the spin cycle the tub does not spin thier is a grinding noise checked the coupler and its ok, and the waterdrains fine i need to find a pictureof the clutch...
could be the tube and clutch/brake assy. If that tube assembly has a problem, the basket won't spin. once you get the agitator off, you can see that large 'nut' that holds the tube assy on. if you can get that off, you should see on each side that there are two 'extensions' on it. If they are bent or non existant, that's the trouble. It could also be the clutch/brake assy. Sometimes the trans. itself will do that as well. If you can get to the pump and motor assembly, see if you can make the agitator move by turning that coupling by hand. Clockwise you see one movement, counterclockwise, it goes different. Check all things
(sorry, I'm thinkin as I type, so it's sorta rambling)
Hope this helps
Joe
Aug 12, 2009 | Kenmore Washing Machines
Trying to connect nintendo wii to philips tv
If I have the right manual you should connect the wii cable from the package to th backside of the tv. You will see four pluges. Choose with VGA you want to use, this is not important. Use the cable from the wii and plug in two of three pluges, you must match te coulors. If you have a cable box installed you will probably have scart (a big cable with a large head) connect this and it would run smooth. You can also connect the three pluges from the cable to your cable-box, use the red, wihte, and yellow pluge.
Dec 25, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Trying to connect nintendo wii to philips matchline tv. the model no is : 42FD9944/01S
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
