Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Computer turns on gets to the login page. very bright..than goes black but you can still see the login but is very dark. if you shine a flash light on it you can see everything. what ive went in to the monitor settings and set it as brite as it goes. but still dark. but when started its perfect. what could be the issue. thanks
    Scholar:
  • 185 Answers
Try an turn off your power management function and see if it corects it. f
Posted on Feb 02, 2010
Toshiba tv goes black
the lamp has gone basicly there is a back light that lights the screen if this bulb goes you cannot see anything but it is all still there only way to fix this is to get a new lamp but sometimes the lamp is on a circuit board and the price is more then the tv is worth
Apr 29, 2012 | Toshiba Televison & Video
My pictures vary from normal to too bright and/or too dark
Pictures being too bright normally mean that you have direct light shining towards camera. try to change angle of photo or else compensate with flash or lighting
Dec 28, 2011 | Nikon D40X Digital SLR Camera Digital...
My 42" hd Sanyo flat
chances are your backlight inverter circuit has failed, repaired one a few months back with the same problem. To verify this, take the tv in a dark room. plug it in and take a bright\ flash light and shine it on the screen. turn the set on, you should see either the screen saver or video from your source. If this is the case, your inverter is at fault. Depending on your model, your backlight inverter is built onto your power supply board so you will have to replace the power supply/inverter board. Not hard to do, you can do it yourself with care.
Sep 23, 2011 | Sanyo 42 in. LCD TV
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Monitor has power. Will come on very briefly and the go to black screen. Can turn power off and back on and get the same above result.After a 2-3 hour period may come to life...may not.
It appears as if the monitor's back lighting is failing. To test the theory, take a bright flashlight and shine it on the lcd monitor screen when it goes black. If you can see the images that were on the screen before it went dark while shining the flashlight on the screen, then the back lighting is failing. Depending on the monitor, it could have florescent or L.E.D. back lighting, but it's usually more economical to simply replace the monitor with a new better performing monitor, than to attempt repairing the back lighting on the failing monitor.
Dec 01, 2010 | Samsung SM225BW 22 inch LCD Monitor
My dell inspiron laptop 1000 screen turns dark every few seconds. if I close the computer half way and open it,it stay bright for a few seconds and turns dark again
This is your back light on your lcd display, To prove that have a flash light handy when it goes dark point the flash light at the screen and you should see the screen and that would mean right there you got a back light going out or the inverter that powers it is going bad. Etherway if this is not your area of work you need to tech it to a computer tech local to have it repaired.
Thanks for being considerate with your ratings and feedback today.
May 04, 2010 | Dell Inspiron 1525 Notebook
WHEN BOOT UP ON MY ACER ASPIRE THE SCREEN REMAINS BLACK, IS THERE A SOLUTION TO FIX IT?
if you have the restore cd for you computer run it and follow the directions,, if not thats it repair shop
Aug 11, 2009 | Acer Aspire 5610-4648 Notebook
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
The Screen is Dark and Cannot be Bright by the Brightness Keys. It Flickers when it first comes on but goes Dark. Can see it if you shine a Flashlight on the Screen. Also the Lid Switch if you Press that...
Assuming all of the connections are secure this is most likely due to a failing LCD inverter which is basically the backlight of the screen. If it's less than a year old cash in on the manufacturer's warranty. If it's not you might as well buy a new one. Hope this helps.
Apr 13, 2008 | Computers & Internet
Monitor displays breifly then goes to blank screen
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
247 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
