The problem is not with the temp control but more with either the evap fan in the freezer section or a heavy frost build up on the back wall toward the bottom section of the freezer. If you have more frost than usual more than likely the defrost t-stat has gone bad which is not a costly repair. The fan you should be able to hear also with the freezer door open. If you do not hear it the fan has gone bad and needs to be replaced. Hope this helps
