Question about Whirlpool GEW9250 Electric Dryer
May tag it heat up but no air is comming of the hose that leads out side
  • 39 Answers
Your vent is propably restricted with lint. Have entire dryer vent system cleaned. Make sure first that the dryer is blowing ok by taking hose off back of dryer. If air comes out dryer without hose attached but no air out vent when hose is attached then the vent hose or duct work in house is clogged.
Posted on Feb 03, 2010
How do I test heating elements and identify leads
The heating elements can be tested for continuity using a voltage meter. Continuity is "continueness". If no continuity, then you need to replace the elements. They are sold based on the voltage and amperage of the water heater. That information is available on the information tag on the side of the tank.
Feb 20, 2015 | Water Heaters
Dryer heats up and finishes cycle, but clothes still damp. It actually smells like something is burning. I already checked and redirected the hose, blew the pipe leading outside, cleaned the filter and...
check air flow were heat exhausts outside. good air flow? sounds like lint clogged. couuld be in dryer, in exhaust hose, id start with hose make sure clear and not kinked.
Mar 10, 2014 | LG DLE2532W Electric Dryer
JEEP CHEROKEE LE DRIVER SIDE HEAT DOESN'T WORK
If you have heat on the passenger side then this is just a simple case of the hose supplying the heat has com off of the heat exchanger
Aug 26, 2012 | 2001 Jeep Grand Cherokee
I have had the ac recharged. Checked the guage and it is full of freon. The air blows on the inside but there's no cold air. What could be the problem?
Water pump or possibly a new radiator hose. Check your main hoses leading to and from the firewall by the driver side leading to what should look like a possible option for your cabinant hose.
Jul 08, 2011 | Ford Expedition Cars & Trucks
Heater does not come on, Radiator fluid full. Fluid heats, heater does not work blower works heater does not get hot or even warm.
Probably air locked. check to see if one of the hoses leading into heater is hot. Other cause could be heater solenoid control valve faulty. Very unlikely that the heater matrix is blocked. Easiest way to bleed heater is to remove hose's when car is cold and GENTLY flush through with garden hose and push hoses back on when full of water, so you know you have a heater full of fluid. Hope this helps
Jan 11, 2011 | 2000 Jaguar S-Type
1999 grand cherikee dual heating zone 1 side hot passanger side cold
If the heat control system is operated by small vacuum hoses, check the hoses under the hood and under the dash at the heater control. The hoses control "doors" or large air-valves which direct heated air. Sometimes the hoses break or become disconnected, and sometimes the doors get stuck.
Jan 01, 2010 | 2000 Jeep Cherokee
Kenmore Elite 73942 Gas Dryer only runs with start button held
Unplug the dryer. Open the control console.Mark and remove the wires from the start switch.
Using a volt meter set for continuity,touch meter leads to R1 and R2 while pushing the switch. No reading is a bad switch.
Touch meter leads to R2 and CT1. No reading is a bad switch.
If the switch checks out good the start windings in the motor are bad.
Dec 27, 2009 | Kenmore 73952 Gas Dryer
2003 Dodge Ram Van 1500 *** NO HEAT **
Do you have enough antifeeze in your cooling system. If not fill & check again for heat. You may have a blockage. If so remove the in & out hoses to the heater core on firewall. Be careful not to damage core. Use a garden hose to flush the core one side to the other untill running clear water. put one hose on tight & clamp, put other on loose. Have someone start engine & slowly remove loose hose to let air escape. when fluid appears put hose on & tighten. Refill rad & resevoir. Heat engine up & check for heat. Also heat cable may be off under dash.
Sep 12, 2009 | Dodge Ram 1500 Cars & Trucks
I changed the thermostat in my 1993 Toyota Celica
Yes, those are the hoses that go to the heater core. Just wondering, you didn't say that air is blowing, is it? You also have other components that "decide" your heat into the cabin of the car. What were the symptoms leading up to you deciding to change the thermostat.
Mar 18, 2009 | 1993 Toyota Celica
Blowing Cold Air
Sounds like a heater core. Check the passenger side floor board. Sometimes when these go out there will be some water on the passenger side floor. Hope this helps some.
Dec 31, 2008 | 1992 Chevrolet Suburban
Whirlpool GEW9250 Electric Dryer Logo
88 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
