Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
A hum comes from the motor, but the door does not open or close, and the orange light flashes but does not turn off.
    President:
  • 3,197 Answers
You could have a bad start capacitor.
Posted on Feb 02, 2010
I have liftmaster professional garage door opener. it opens ok but does not close with remote and light keeps flashing on garage door opener. I checked both sensors and seems like the sending sensor light...
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
When I start the dishwasher it seems like the motor hums,water comes on but then it stops. When I open the door the control panel is flashing pots and pans and heavy when I had selected normal for the...
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Apr 30, 2010 | Viking DFUD142D Built-in Dishwasher
I have a Craftsman garage door opener model 139.53325SRT 1/3 HP, it was working fine and then it would not open, when push the wall switch, the opener hums and the light starts flashing, I have removed the...
It sounds like your door sensors may be misaligned. If when you try to close the door the main light flashes 10 times and the door reverses to the open position this is the case. Make sure the small light on each sensor is lit and not flickering. Tweak the sensors to see if you can get both lights to come on. If not you have a bad sensor.
Feb 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor hums,but it does not close. Light works and
Is the trolley jammed against the bolt just in front of the motor unit? If so remove the bolt and then run the door until it is closed. Now locate the 'up limit' control on the side of the motor unit and turn it 2 full turns in the opposite direction of the arrow printed on the cover. Remember to replace the bolt.
If this isn't the case you could have a bad start capacitor.
Nov 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor humms but door doesn't go up or down!
5 flashes is the code for "RPM sensor board or motor overload." If your door is stuck in the open position the trolley may be jammed against a bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. Now locate the 'up limit' control on the side of the motor unit and turn it a couple turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
The door does not respond when using the remote inside the car
If the main light flashes 10 times when the door reverses it is a door sensor problem. Look at the LED just to the left of all those white wires and see if it is flashing a code. It will flash a number of times and then pause if it is sending a code. If the code is 5 then you have a bad RPM sensor board which is just in front of the motor. Also try increasing the down force just a bit. This control is on the rear of the motor unit.
Jul 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor clicks but will not open door
motor is over heated shut down unplug 30 min
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2hp won't open/close and learn LED flashes 5 times
The gear needs to be changed kit #41c4220a. Be sure to change the bottom bushing on the motor mount.
Jan 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
