Ruth's brother just went away to college this fall and had to buy his own laundry soap and fabric softener. the laundry soap was twice the cost of the fabric softner.The total of the two items was $7.47. how much did the laundry soap and the fabric softner cost individually.
    Guru:
  • 509 Answers
Laundry soap $4.98, fabric softener $2.49
hope this isn't someones homework..lol
Posted on Feb 02, 2010
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
Laundry detergent drawer stuck
I had the same problem - the fabric softener cup cam loose and I had to break it to get it out and the new drawer cost me about $65 to replace. I hope you made out better than I did.
Dec 13, 2009 | LG WM-2077C Front Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
How do you get rid of the musty smell in a front load washer.
38c7a1e.jpg MNTECH
Rank: Guru
Rating: 93%, 650 votes
Here is a response I recently gave to a person posting a similar problem. You do not state your model number, so: If you have a tub clean cycle, use that, if not, use the longest, hottest cycle with no clothes and a front load washer cleaner like Ahfresh, Washer Cleaner, SmellyWasher Cleaner, Tide front load washer cleaner, or Whilaway hot tub cleaner. Clean the tub gasket area by the door and remove the filter and clean it out also before you run the clean cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer. Now, after the washer is clean, USE ONLY ONE TO A MAXIMUM OF TWO TABLESPOONS OF HE LAUNDRY DETERGENT PER CYCLE !!!! (and no more than one teaspoon of fabric softener per cycle, if you use it)
You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
Aug 12, 2009 | Kenmore Elite 45986 Front Load Washer
How to wash quilt fabric in the front loader.
You will have to experiment a little, You will use less soap and add fabric softener to the soap. The fabric softener helps decrease the sudsing action of the soap. This is not condoned by the manufacturer, but it does work.
We use a powdered soap and have found that about 1/3 the soap and just less than a 1/2 cap of softener works best. (the soap we prefer is not available in a "he" formula). Mix the soap and softener prior to adding it to the machine. works for us, hope it works for you too.
Feb 13, 2009 | Frigidaire Affinity ATF7000E Front Load...
My front loading LG washing machine doesn't seem to wash as well as I had expected. Actually the only things that I have noticed this in is the wash cloths and towels. They are getting a gray dingy look to...
Once the dingy look gets into them, it seems to be impossible to get out. It is caused by using too much soap and / or fabric softener. Remember, your front load LG is using only about 12 gallons of water to wash those towels. Your old machine used as much as 45. This means that all wash loads need to use less soaps and fabric softeners. Use 1 tablespoon of regular HE detergent for standard loads. (only a teaspoon if it is 3X HE) Only a teaspoon of fabric softener when you use it. Which brings me to towels. If washing bathtowels: You are clean and rinsed before you use the towel. The towel is not getting dirty, only soaking up the clean water off your body. Hang them on a towel rack and use them several times before washing, and when you do wash bath towels, most of the time you do not need any detergent, as they are really not dirty. Of course you should know that you never use fabric softener on loads of towels. Now, back to the dingyness. The dingy stuff is residual soap / fabric softener in the fabric, which once machine dried seems to be impossible to remove. If they are white towels, make sure to use liquid bleach and you might try to use a little Mrs. Stewart's concentrated liquid blueing in the fabric softener dispenser to see if if might help. Most likely you will have to try a few new towels, washing with no soap or fabric softener when laundered.
Please don't rate this, as it is really just informational, not what most people would call a solution, and any rating other than FixYa drops my score.
Note: If you wash some previously washed towel, using no soap, you should not see any soap suds in the washer. If you do, you are seeing soap left over from the previous washing of the towels or soap from build up on the outer washer tub. Use Whirlaway or AhFresh on tub clean cycle or at least the longest hottest cycle you have, and start using the correct amount of laundry additives. (also will help prevent odor issues)
Nov 23, 2008 | Washing Machines
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Smelly clothes
A solution from the internet:
Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda.
It should clean the machine and move out the bad smell.
Another:
I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution.
MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts.
They are not very cheap but they work great --
I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain.
YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health!
I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine
And dont forget to rate me pl. Merry Xmas to you too.
Dec 22, 2007 | Washing Machines
Moldy Smell
try running about 3 cups of vinegar in your washer and always leave the door open when you are done doing laundry
Dec 10, 2007 | Kenmore Elite 45986 Front Load Washer
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
