Question about Panasonic SC-PT770 Theater System with Wireless Speakers
How can i hook the speakers that come with thePanasonic SC-PT770 Theater System up to a different audio reciever
    Brigadier General:
  • 8,546 Answers
Don't. Or do so with the understanding that damage may result to the speakers or the new receiver. Theater Systems are not designed to be mixed and matched like true separate audio components.
This unit's amplifiers and speakers are rated at 3-ohms. The speakers may present an unusually low impedance to the new amplifier, which, if it's a 'standard' amp, will probably be spec'd for 6-ohm or higher loads.
Not knowing to what receiver you want to connect them:
IF you want to try it, don't destroy the existing speaker connectors; instead, get some standard speaker wire or lamp cord (the cheapest option) and decide for each speaker wire which of the two conductors you want to be plus and which will be minus. It really doesn't matter which is which as long as you have consistency throughout the listening room. Mark Plus on each end of the designated Plus conductor. (I usually just separate the two conductors up the middle of the insulation and tie a small knot in the Plus). Attach each speaker to its corresponding channel of the new receiver, keeping the plus minus pattern in mind.
Start with VERY LOW VOLUME and listen for any strain or distress in either the speakers or the amp. Don't be surprised if the amp shuts down to protect itself at high volume levels. If you smell smoke, it's too late.
Posted on Feb 02, 2010
The other day I came home from work and my Panasonic SC-PT770 would not turn on. I made sure everything was plugged in, all wires were connected, and flipped the circuit breaker. The manual said to plug it...
Did you check the outlet that it's plugged into? Sometimes we see defective outlets in surge protectors. Check the end that plugs into the receiver also, unplug it, then reconnect it.
Feb 25, 2011 | Panasonic SC-PT770 Theater System with...
My toshiba tv was in the garage for a month. It is now flashing dew protection please wait
Let the tv warm up for a day or so before trying it...there is a sensor in the set that will sense condensation and keep the unit from powering up so that it won't get damaged by the moisture
Jan 18, 2011 | Panasonic SC-PT770 Theater System with...
Panasonic sc-pt760, can't select aux or dvd or anything except am/fm.
I found an online manual you can browse through as I try to assist you with this problem:
http://service.us.panasonic.com/OPERMANPDF/SAPT760.PDF
When using your remote, press AM/FM then press the > or < keys to get to AUX or DVD
Jan 18, 2010 | Panasonic SC-PT770 Theater System with...
I have a Panasonic SC-PT760 that won't turn on!
if it was stored in a damp area it may take awhile for it to turn on until it dries out.most units have a dew protection sensor on them
Jan 17, 2010 | Panasonic SC-PT770 Theater System with...
Panasonic SC HT940 home theater doesnt work with my LCD TV
the HDMI cable sends dato TO the TV, it does not have enuf bandwidth to send both to and from, just TO.
Dec 27, 2009 | Panasonic SC-HT940 System
Just bought a panasonic home theater sys.. cant
try to look for the settings that the source will be in ipod dock, if there is.
Oct 04, 2009 | Panasonic SC-PT770 Theater System with...
Would like to listen to tv through the 5.1 speakers and don't know how to hook them up to do so, please help
You can run red and white from tv out to in on reciever, or optical out tfrom tv to in on reciever or digital coax audio from tv out to in on reciever, depending on which connections you have. then you would put your reciever on aux to hear tv through surround system. Also if you have a cable box or satellite box you can run the audio from that box to the input on surround system.
Hope this helps.
May 05, 2009 | JVC TH-G30 Theater System
Need Help
Sounds like you have a loose cable. Check that the connection is really in well. If the problem continues I would get a new set of cables, especially if you are using the ones that came with the receiver or dvd player.
May 05, 2008 | Audio Players & Recorders
Panasonic SC-PT770 Theater System with Wireless Speakers Logo
157 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
