Question about Microsoft LifeCam NX-6000 Webcam
Has an Initialization error and doesn't show.
Has an Initialization error and doesn't work on any program.
  • Microsoft Master
  • 2,844 Answers
Check out the Microsoft support - enter the camera details to navigate to the support page for your model - read the 'Breaking and known issues' link and any additional software required for your model
http://www.microsoft.com/hardware/download/download.aspx?category=ICE&type=LifeCam&sku=68A-00001
Posted on Feb 03, 2010
Toshiba E studio 182 power initialization problem
On startup, if the machine shows a wrench-icon, press down "8" and "clear/stop" key simultaneously to show the exact error-codes. A list of detailed error-codes can be found here: http://officeimagingsystems.com/id175.html
Jun 27, 2014 | Toshiba E-Studio 182 Copy Machine
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
I have a te-2200 but cannot get past the initialization. Machine initialization procedure. I keep getting a e004 error
Which MAC code are you typing in? Have you used the table in the dealer manual to work out the correct code for your country and programming needs? If you need the dealer programming manual, there is one here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Jan 10, 2011 | Casio Parts Cash Register PC Desktop
Indesign cs3 me quits shortly after start
Your computer might have been infected. Please re install the program.
Apr 16, 2009 | Adobe InDesign® CS3 5 Upgrade Version for...
How to uninstal avg 7.5 ?
try to download the avg8 from here and install it. then if you want to uninstall run uninstaller from controlpanel for avg8.
the avg8 should be able to remove avg7
Feb 24, 2009 | Microsoft Windows XP Professional With...
Initialization error showing on Lifecam vx 5000
Try reinstalling using the info below.
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jan 13, 2009 | Microsoft LifeCam VX-1000 Webcam
LG TV 42LB1DR INITIALIZATION PROBLEM
mine did the same thing once, I unplugged it long enough to make sure it shuts down all the way and let it reset itself. Turned it back on and it was and is fine [it's been 2 mos. now] That worked this time.
Last time one of my kids spilled something down the back and it gradually went out. 600.00 to have the part replaced.
oz
Jan 01, 2009 | LG DBRH197H DVD Player/HDD Recorder
Initialization Error
hi friend,
there are few steps to stop the message in the start up. i tell you the step by step.
  1. Goto Run type msconfig
  2. Goto startup tab and see all the files that are in the startup files and unselect the Hkdrv files in the startup
  3. it will ask you to reboot the system.
  4. After reboot the system and in the begin of the system it ask you to the accept the changes in the start up and choose the dont show this message again in the start up and click ok.
  5. After this it ask you the same thing .please inform to fixya.com
bye thanks,
Jun 14, 2008 | Computers & Internet
Microsoft LifeCam NX-6000 Webcam Logo
212 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
