Question about Brother MFC-8480DN All-In-One Laser Printer
Brother Printer 8480DN. How do I print an address
Brother Printer 8480DN. How do I print an address on an envelope?
    Problem Solver:
  • 13 Answers
If you have Microsoft Word, open it, go to Tools, Letters and Mailings, Envelopes and Labels. You will have to set up the options for your particular printer. It works great with my Brother
Posted on Feb 02, 2010
My Brother 8480DN will not accept envelop
on most printers you have to reset the paper thickness for envelopes or it will read a jam
Jul 22, 2016 | Brother MFC-8480DN All-In-One Laser...
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
Double printing addresses on envelopes
You need to make sure you set up for envelopes in printing preferences as this makes the fuser a little hotter. If all is set up properly you need a shop to adjust the fuser temperature. The thick envelopes require more heat to bond the toner properly.
Feb 05, 2010 | Brother DCP-7020 All-In-One Laser Printer
Bends envelopes in printing
Most laser printers have an "S" paper path. They cannot help bending paper. I would suggest you print lables instead of envelopes if you send several letters. If you only send 1, hand address the envelope. Not elegant ut it works.
May 28, 2009 | Brother HL-2040 Laser Printer
Printing envelopes
Open a MS Word Document, select 'Tools' then 'Letters and mailings' then 'Envelopes and labels...'
Envelopes and Lables dialogue box opens - ensure you are on the 'envelopes' tab
Then type your recipient address in the larger white box
for standard letter envelope (DL 220m x 110mm) - Insert envelope into Brother HL-2030 manual feed, with print side up, gummed flaps down and to the left side (bring gray plastic guides in close to secure).
Then select print.
I have found that during the feed, one end of the envelope gets a little bit crumpled but overall it's still a little bit more professional looking than my handwriting.
Jan 12, 2009 | Brother HL-2030 Laser Printer
Printing envelopes
Pull down the front and slide the paper guides together till they are the size of the envelope. Place your envelope front side up (return address will be at your bottom left)
Apr 01, 2008 | Brother MFC-8460N All-In-One Printer
Envelope printing
You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
Thanks J
Feb 03, 2008 | Brother HL-2040 Laser Printer
Envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER IF YOUR DARING.)
Jan 29, 2008 | Brother HL-2040 Laser Printer
Brother MFC-8480DN All-In-One Laser Printer Logo
219 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
