Question about Sony Ericsson W850i Cellular Phone
Water damage i have this w850i and i accidentaly dropped it in the sink, i was currently talking to someone when it dropped. i quickly removed the battery. the lithium paper already turned red, both on the phone and in the battery. i dried it up as fast as i can. i immediately bought the phone to the sony ericsson repair shop, but they said my phone is already beyond repair due to the corroded motherboard. is there anything else that i can do to revive my phone? that phone is really special for me... i dont want to give it up just like that...
  • Muffinman08 Feb 20, 2008
    Same thing happened to me the same day! Got it out within seconds, turned it off, stripped out battery, 2gb memory stick & SIM. Dried it with kitchen towels then atop a radiator which cured the condensation behind the screen too.
    Several people I know have done this and got away without any damage. Mine now has a keypad logic fault that effects 7 and some others inc the ok select. Press certain buttons - it does something else etc.
    Is this worth fixing? Any help on this will be gratefully received :-)
Get a new phone :P
Posted on Feb 24, 2008
Ice maker is frozen solid how do i remove ice without damaging
remove icemaker from freezer and run just the part where the ice is made(not the front part) over running water in sink would melt ice quickly
Aug 11, 2011 | Hotpoint HSS25GFP Side by Side...
My phone scrren wont light up. i had left my phone in the bathroom while i was bathing and the room was filled steam.When i come out of the bathroom i check my phone and the screen was covered in steam....
the worst for phone is water damage.in your case lcd is damage.must change.but its not guarantee for property work on your mobile cos water may damaged other parts of device.ALWAYS KEEP PHONE FAR OF WATER
Dec 09, 2009 | Sony Ericsson W850i Cellular Phone
All my music and videos are gone and the screen is messed up from the inside. I dropped my itouch in the sink of water for one second and immediately dried it but it seems to has some problems what should...
1) Sell it on eBay to help cover the cost of a new iPod, you'll probably be able to get 50-70 dollars for it.
or
2) Find and pay someone either on eBay or another website who are able to fix water damaged iPods.
Nov 12, 2009 | Apple iPod touch
My nokia 7610 phone has been dropped in water
You should detached quickly its battery first. It is to prevent further damage to your unit. And dont try to power it on. Then bring your unit to a cellphone shop to have it dry and clean it for you, they will sometime automatically charge for water damage repair.
For minor damage only battery pack will get damaged. Luckily only cleaning and drying will get it running.
Apr 17, 2009 | Nokia 7610
My mobile sony ericsoon W850i no open only flash
I think that your sony ericcson has been dropped somewhere or it is water damaged, if its a white screen which keeps flashing then its overheated or water damaged, it may need a new battery or will be about £30 GBP to fix. If this helps then please vote me!
Thanks
Jan 17, 2009 | Sony Ericsson w580i Cellular Phone
Stk392-120 replacement
They are no doubt stuck on to the heat sink because the thermal grease which helps to conduct the heat out of the module drys out over time and acts like glue. Just whack on it good or pry it off. Make sure you don't gouge the heat sink though and you will want to scrape off the old grease and put on some new grease under the new modules and tighten them down till the grease squeezes out underneath.
Hope Ya Fix it!
Mar 05, 2008 | JVC AV-48WP30 48" Rear Projection...
My w850I has been wet 4 along time wont work
ITS PROBABLY CHEAPER TO BUY A NEW PHONE WATER DAMAGE ALWAYS DESTROYS ELECTRONICS
Jan 17, 2008 | Sony Ericsson W850i Cellular Phone
W850i water damage?
Hi Aky,
The best thing to do is to take the battery out leave it to dry and your phone do not try to charge the phone for a few days that should solve the problem. if not the water has gone into the liguid lcd screen.and the lcd screen need to be replace.
Jan 15, 2008 | Sony Ericsson W850i Cellular Phone
Some buttons on the keypad won't work
I strongly recommend consulting the supplier, he/she is bound to know what to do, they may also give you a new handset!!, by the way may i comment on the good phone!!, but yeah, if they are unable to help, take it to a certified phone shop/dealer, they will know what to do!! BUT DO NOT mess around with it yourself!!, this could void your warranty and may definitely do more harm than good! is there any water damage, i have researched and found that this problem happens A LOT when there is water damage on the phone, check the moisture on the battery, there should be a moisture detector on the top of the phone, if this is pink, than it has been affected by water damage, ive also found someone who used SEUS to flash his phone, he said that the buttons were stuck and he had the same problem as you, when he flashed it he said that the phone had restored itself! i recommend trying it yourself BUT BEWARE that you can void your warranty if you do so!! but definitely contact the owner first!
hope this helps and keep ion touch!
Jan 09, 2008 | Sony Ericsson W850i Cellular Phone
Dropped it into sink
was there water in the sink at the time?
if so check the connections on the base if there is green corrosion on it the the damage is done you will have to find someone who will repair water damaged phones.
If no water and just the drop that caused the prob then try removing the battery while the phone is still turned on this may shock it back
Nov 17, 2007 | LG VX9800 Cellular Phone
Sony Ericsson W850i Cellular Phone Logo
89 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
