Everytime i open iternet windows script host appear with the following data: Line 24, Character 1, Error permission denied, Code: 800A0046, Source:Microsoft VBScript runtime error. Please help me to solve this problem. its quite irritating
  • 742 Answers
It is a Windows Internet Explorer bug that could be fixed by upgrading your IE to version 8. Also, check your "home page"found at Tool => Internet Options and set it to some legitimate website. The error message simply means that the page you are viewing has scripts that return an error.
Posted on Feb 02, 2010
No space for new apps
· 1.Check if you really have sufficient storage free.
Ifstorage is free enough
then
· 2.Clear the app chache data with the clean master app or the included cleaning app forjunk data cleaning.
Can also bedone by using adb bridge (Search on the net you will surely get something onstackoverflow.com).
If thisdoes not solve your problem.
Then try this:
· 3. (This solved my problem)
Usuallythe default install location in android is set to automatic. If for any reasonif it is change to something else it can be problematic like you experienced.
Setting up ADB (required)
->get you phone connected to a pc over the USBcable provided (Make sure you have your proper driver installed [usually it'sinstalled])).
->Turn the "debugging mode on"through the settings (You can search over the internet it's easy)
->download the adb_inteface.rar tool andextract it somewhere.
->open command prompt. Change the currentdirectory to where you extracted the adb.exe and all files from the attachment.
->type
adb devices
if it returns with last line like this
List of devices attached
cfcd5eec device
This means you have successfully set up theinterface.
Running Commands
->check the default storage location bytyping on the command prompt:
adbshell pm get-install-location
If it results something like:
open: Permission denied
2[external]
Or
1[internal]
This means it may be a problem which forces the Android OS to save on specified location 1 for internalstorageand 2 forexternal storage.
You may fix this by running the following command:
adb shell pm set-install-location 0
here 0 means automatic storage depending on the storage space availability.
Meanwhile you may get messages like:
open:Permission denied
open: Permission deniedYou can ignore this.
this is probably because your phone is notrooted.
Hope this is useful.
May 25, 2015 | CUBOT Unlocked S222 Andriod Smartphone...
So how can I restore my v b script host on my netbook with windows 7 ?
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
Jan 15, 2013 | MSI Ge620-021us 15.6in Hd 1080 Led...
Fix my vb script engine on my computer / Windows 7
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Script error while going to yahoo chat room
First try to enable scripting through Internet Explorer
Go to Internet Explorer,
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
I hope it will work.
Please let me know.
Thanks.
Mar 31, 2012 | Yahoo Messenger
When i enter the chat room i got the notice... a error has occured in the script on this page line:7 char:2888 error:permision denied code:o url:...
when am trying to enter chat room after entering the capache code it showing >>>>An error has occured on the script on this page .....Line : 7 ..... Char : 2888..... Error : Permission denied .... Code : 0 ...... URL : http://yui.yahooapis.com/2.4.1/build/connection/connection-min.js ......... Do you want to continue running scripts on this page? YES NO <<<<<<<<< It showing like this in one Script Error box please Help me how to solve this problem am getting mad with this .....please help me
Jul 12, 2011 | Yahoo Messenger
A error has occurred in the script in this page
Reinstall / Update Java software on the system.
Sep 22, 2009 | Dell Dimension C521 PC Desktop
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.2; Trident/4.0; Data Center; GTB6; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648;...
The key part of the error message is "permission denied", so it is one of two things.
It is either exactly that, you need to log into the server and set the permissions to "Read, Write, Execute" in the everybody group, OR there is something on that line of code that the browser security finds unsafe. You can test that out by setting your security real low for just a moment to try again, if you are sure it is safe to do so.
Sep 19, 2009 | Computers & Internet
Fix dell 942 printer
what operatin system are u using on this prnter ?
Jul 10, 2007 | Dell 942 All-In-One InkJet Printer
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
