Question about Bosch Washing Machines
Hello we recently bought a second hand wfl 1800 Bosch washing machine It's problem is that it immediately starts washing after it has finished its wash-spin cycle and doesn't give enough chance to open the door to remove the cleaned load before it starts again. Do you know what the problem is and how to fix it? Any help will be greatly appreciated. Adam.
  • 1294 Answers
SOURCE: Bosch WFF 1800
There is no draining & this is why your spin does not work. There is only one belt. First siphon out the water from the machine via your front door. Clean out your outlet filter, check the tube from the tub to the filter. Luckily there shouldn't be a block in your outlet pump
Posted on May 21, 2007
  • 139 Answers
SOURCE: Bosch Maxx WFL 2260
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
Posted on Jan 17, 2008
SOURCE: bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Posted on May 11, 2008
  • 135 Answers
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
May 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch wfl 1800 starts filling then stops with a ticking/clicking noise near controls
motor brushes are probably worn out will need replacing not expensive but have to remove motor to get at them.
Oct 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Jul 21, 2009 | Bosch Washing Machines
Washing machine malfunction
The latch might be an issue . Move the dial on pump mode . Try activate the door lock with a screw driver move it to the right and should activate the machine. If that works then the latch is the issue and can easily be repaired by removing the door.
Aug 09, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Bosch washer too long cycle times
Looks like the heater has failed.Contact Bosch direct to repair as it has a 2 year guarantee
Mar 15, 2008 | Bosch WFL 2463 Front Load Washer
Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Jun 10, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
