Question about Haier HSB03 Compact Refrigerator
I have a haier mini fridge that wont cool.
I have a haier mini fridge and the fan blows fine, lights are on, and it sounds good... just doesn't get cool. What could be my problem?
  • Lorenzo McEwen
    Lorenzo McEwen Feb 02, 2010
    I take it, the compressor is that amplifier looking unit behind the running fan? If so, that area is not warm at all.
  • Lorenzo McEwen
    did you receive my last post?
  • Haier Master
  • 43,501 Answers
Thermostat or compressor... Check the thermostat by seeing if you are getting power to the compressor. If so then the compressor is bad. Is the compressor getting hot to the touch and not running? Becareful it may be VERY hot!! Then you are getting power to it...
Replacing a compressor in one of these units may cost more then a new one. Becareful before investing money in it.
Heatman101
Posted on Feb 02, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Feb 02, 2010
    If the compressor is cold then you may not be getting power to it. Trace the wires to see where the power stops at. It may be the thermostat that is bad.
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
I have a Haier Wall Air Conditioner. It's on cool
Filter may be clogged. I have one and it has a filter which I clean regularly.
Sep 11, 2012 | Heating & Cooling
Ck engine light problem on 2001 Impala
Well the code is for the circuit - the computer commands the relay to turn the fan on and it doesn't happen.
The computer provides the ground for the relay.
If you have replaced the relay and the fan and the fuse still blows, I would look for a problem in the harness between the fuse box and the fan, including the ground circuit for the fan.
The fuse for the cooling fan is usually a 30amp marked "cooling fan" in the fuse box in the engine compartment.
Do you know what the 25amp fuse that is blowing is for ?
Jul 30, 2012 | Chevrolet Cars & Trucks
My fridge in my camper wont cool but the freazer is working fine. what do you think? light works and all just wont cool, thanks Lauro
there is a fan that blows cool air from the freezer see if there is ice build up if there is deforst it , if it is fine see if the fan is turning if not the motor went out check to see if wires are loose good luck
Sep 15, 2011 | Electronics - Others
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
My fridge wont get cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 12, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Haier fridge- freezer fine, fridge not getting cold. cooling fan for fridge not coming on
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Apr 05, 2009 | Haier HTE18WAA Top Freezer Refrigerator
I have a mini fridge at school, a small Haier. My fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
Hi ejb9,
I'm Harvey the Master Plumber.
Your question is: You have a mini fridge at school, a small Haier. Your fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
May be low on freon or cloged expantion valve. You're going to need a certified tech to check and repair. Maybe it's time to look at the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Haier Refrigerators
Haier hrt02wnc compact refridgerator 1.7 cubic
I have a Haier mini fridge model hrt02wncbb it will not cool, The fan runs all the time. I keep it in my class at school but there is five other mini fridge they work find what should i do?
Apr 13, 2008 | Haier HRT02WNC Compact Refrigerator
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Haier HSB03 Compact Refrigerator Logo
477 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
